Sigma 28-70mm f/2.8 EX DG for Canon EOS Logo
Posted on Dec 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Using old Sigma AF lenses with new DSLR Canon EOS
I have 2 AF Sigma lenses which were used with a Canon Eos 10 film SLR. Does anyone please know whether they would work with a new DSLR Canon Eos (and if so which one). The lenses are:
1. Sigma EX 28-70mm Aspherical
2. Sigma 70-300mm APO Macro
Many thanks
Mark from Surrey
Gary Maitland
Level 2:
New Friend:
  • Expert 117 Answers
  • Posted on Jan 01, 2010
Gary Maitland
Expert
Level 2:
New Friend:
Answers
117
Questions
0
Helped
50551
Points
145
Hi Is the 28-70 a DF type if so it will work on a canon DSLR but if its the older one with the scale ring is on the outside of the lens it will need a rechip but I think thay are no longer avabile the 70-300 if is a super it will work or need a rechip if its a older one with a macro switch held on the lens with 2 screws it to old to up grade
1helpful
Are older Sigma Quantaray lenses that I used with a 35 mm SLR Canon Rebel 2000EOS compatible with new DSLR Canon bodies?
Yes. Bear in mind that many Canon digital SLRs have a sensor smaller than a frame of 35mm film. This results in the image being cropped, narrowing the field of view and making the lens behave as if it was of a longer focal length.
I just purchased a Sigma 2.8 f=28mm for canon but I don't know if it will fit my Canon EOS 500 N (same as Rebel G) 35mm SLR film camera. Can you help with this question.
Canon EOS 500N has an EF lens mount, so all lenses with Canon EF mount will fit. All lenses with MF and EF-S won't fit. If you purchased Sigma 28-70mm f/2.8 EX, then it have EF mount and will fit EOS 500N.
Does the Sigma 70-300AF APO Micro Super lens fit
Please visit to:
http://www.sigmaphoto.com/sigma-lens-finder
Can I buy an adapter to use the 28-200 mm Sigma Aspherical lens fitted to my Pentax MZ-50 film camera on my Canon EOS 1000d DSLR. Would it work?
You may be able to find an adaptor, but I doubt it and you would lose many functions in any case. It could end up that the lens will not auto focus or that it would not meter properly. These adaptors are made so that specialty lenses (such as fisheye or shift lenses) can be mounted on cameras when needed. Your 28-200 would probably be cheaper to by in an EOS mount.
1helpful
2answers
Which dslr cemera is best for Sigma 70-300mm f/4-5.6 DL Macro
It could Canon, this is one of the edge Canon over other brands. Its versatility on lens mount is better.
What camara can i use with a quantaray 100-300 af lens
You can use a Quantaray lens that fits on a Canon EOS film camera body on any Canon EOS camera body - film or digital. Your choice of EOS camera depends on your budget and your needs.
I recommend starting out with a used or refurbished model - let someone else eat the depreciation on the camera. After you have shot with a digital SLR for a while you will have a much better idea what features matter most for your needs and can make a better decision what new(er) model is the best fit for your money. Obviously you know a bit about photography having used a film EOS camera but there are many things that are different about a digital body. One of the biggest differences is that they come out with a new camera several times a year, and a camera body that is just 2-3 years old will be 2-3 generations old, and worth only a small fraction of the price it sold for new - unlike film bodies that held their value much longer.
1helpful
Cannon lenses
All canon EF lenses (and compatibles e.g. Sigma EX) can be used with both analog and digital  EOS-bodies. Depending on the sensor size (usually smaller than a 35 mm negative) a crop-factor due to the smaller field of view must be considered.  Example: Canon EF 50mm/1.8 lens used on a digital EOS (40D, crop factor 1.6) equals a 80mm lens (50mm x 1.6) compared to analog cameras using 35mm film. Some digital EOS-models can also use EF-S lens-series.
Top Sigma Cameras Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Sigma Camera Expert? Answer questions, earn points and help others
