Since you are using XLR cable, verify all conductors come through pin for pin. Not uncommon that a shield connection gets broken.
Then verify the phantom power is getting to the mic. Use a voltmeter between pin 2 and 3 each to pin 1. You should see a minimum of 9 volts.
Testimonial: "i checked all that and finally had the mic itself checked out turned out the diaphram was busted...."
