Turn the remote over and look for the sliding door on the back bottom right (it has a circle and some arrows on it, push in the direction of the arrows) the cable is under this door. Then connect that cable to the helicopter by plugging it into the white slot next to the on/off switch.
There is a place next to the on switch and it is white , plug the wire charger in to the helicopter and that is how you charge the mini rc ah-64 helicopter
SOURCE: Yiboo AH-64 3D RC Mini Apache Helicopter
There is a small set screw on the bottom gear that holds in the upper shaft. You can see these gears through the belly of the helicopter. I had the same problem with the top rotors, and had to go in and re-insert the rotor shaft and tighten the set screw. I applied locktite to the threads to prevent it from backing out. It works now, but one problem I notice is that there must have been a spacer bushing between the two gear wheels. Without the bushing, it will still fly, but I can feel some play in the upper shaft and wonder if over time that the counter spinning gear wheels will start to wear against eachother.
