Maytag Gemini 30" Self-Cleaning Freestanding Electric Double Oven Range - Stainless-Steel Logo
Posted on Dec 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The Maytag Gemini is didplaying an f9-3 code, what does this mean?
Anonymous
Level 2:
  • Expert 232 Answers
  • Posted on Dec 25, 2009
Anonymous
Expert
Level 2:
Answers
232
Questions
Helped
82999
Points
703
Somthing wrong with upper door lock, bent, door misaligned, problem with lock itself
1helpful
Getting a F1-4 error code on my Maytag Gemini model # 6772. Came home to the upper oven at full heat with the control panel beeping. Extremely dangerous situation where the oven would not shut off at the...
Hi greg_shanoia,
The F1:-4 error code means "Runaway Clean Lower oven". You need to check the oven temperature sensor, replace if necessary.
Hope it helps.
Thank you for using FixYa.
2answers
Range displays error code f9-5
HI. This indicates that there are serious issues that concern the operational value of the main control abord(ERC/Clock).
This will require you to replace the ERC, asap.
ERC_(Electronic Range Control Board)
F9-5_Hardware conflict(watchdog)
Maytag gemini model MER6770AAB - F1-2 error
Check the sensor for correct ohm reading. If it is good, replace the control. It should read 1143 at 100 degrees
How do i get fault codes for maytag gemini?
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, there is an "Error Code" link listed under the Special Features section. The Maytag Gemini series fault codes are listed there. You can print the list for FREE. I hope this helps you.
3helpful
2answers
Maytag Gemini Stove Code F1-4 (bottom door won't open)
F-1 error is a Temperature Runaway. It Maytag's way of letting you know that oven overheated. Nothing you have done but it may have shorted out the oven sensor or the keypad. Check the sensor and see if it's closed. If it's okay, replace the keypad.
4helpful
F1-6 Fault Code
This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
Maytag Gemini fault codes.
Fault code Suspect area Fault code Suspect area
F0 - 0 None
F1 - 1 Runaway cook upper oven
F1 - 2 Runaway cook lower oven
F1 - 3 Runaway clean upper oven
F1 - 4 Runaway clean lower oven
F1 - 5 Keypad cancel upper
F1 - 6 Keypad cancel lower
F1 - 7 Keypad disconnected
F1 - 8 Keypad shorted
F1 - 9 Slave
1helpful
F 1-4 Error Code
f1 is usually bad oven control board. Look for a tech sheet on the back of the oven. This will tell what all of the codes mean and what to check for.
2answers
Gemini electric range from maytag
Just unplug it and plug it back in. It will reset it.
3answers
Maytag MER6772 Gemini ELectric Stove
F9-3 code means the latch on the oven is faulty. http://www.partstore.com/GetModel.aspx?MfgName=Maytag&BrandName=Maytag&ModelNumber=MER6772BAQ&PartCategoryName=&Keywords=latch
Top Maytag Kitchen Ranges Experts
vince
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
