Sansui  27 inch TV Logo
Posted on Dec 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv shuts off on automatically - Sansui 27 inch TV
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 318 Answers
  • Posted on Jan 04, 2010
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
318
Questions
0
Helped
86230
Points
527
Check the tv sleeping time if its activated or not.
if its not activated then check the power supply
okay
Diagnosing tv auto shut down.
The TCON board is not junk, if anything it is the mainboard that is faulty.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
My tv automatically shuts off then power button flashes 11 times. Can't get tv turned back on
11 blinks Fan SOS PB Board. Either the cooling fan or its control board is faulty. You have to check and locate which one has the fault. Check this link and select the site mamed 'Electro-help' for more details.
2answers
I have a RCA HD52W59 TV. Shuts off automatically.
Power supply is my initial thoughts, but then again it could be that one of the three CRT's tubes has an issue.
My thoughts is that it would be best to bring it to a good TV repair shop.
Why spend money on a power supply and then find out it's a CRT.
Blessings,
A/V Media Guy
4helpful
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
3helpful
Sony TV shuts off automatically
1.Check first if the shutdown of your tv follows a certain period of time. Example after using it within 12 hours it automatically shut down. If so the the matter is only on settings of your tv.
2.But if your tv shut down at an irregular time the problem is in your board. In this case if your tv still work but still shutting down automatically its better not to use it so that their will be broader damage.
3.The most common defect on this case is loss contact of components due heat and mechanical undergone during the usage of the tv. If you know how to resolder board, try to resolder the components specially those who are showing loss contact. You can recognize it because a good solder one has shinny and no round like on the soldered surface.Try also to resolder important parts such as IC's and transistors. note : a good resolder needs to be done in order to avoid problems and damage.
4.Another possible cause is the tack switch for channels,menu,power and etc. You can remedy it by spraying it a contact cleaner.
5.If the problem still going even after the procedure its better to bring it on reliable and trusted service center.
1helpful
Since your plasma is less then a year old, I would suggest to contact the manufacturers to get it fix under warranty. If the plasma keeps shutting off by itself, that is not normal and should be repair.
3helpful
2answers
Tv shuts itself off
Look for the computer processor inside the TV. It needs to be cleaned. A can of compressed air will work. The processor is overheating and causing the tv to shut off. Look for the small fan that is supposed to keep the processor cool then remove the dust.
Setting automatic shut off
How do I set on PCB to automatic tv shut-off?
I Can Assure You That This Problem Is Associated With 2 Capicators On The Power Supply Board.
Top Sansui Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
