Brother HL 1470N Laser Printer Logo
Anonymous Posted on Dec 24, 2009
Power recently went out and we were on generator power. Now, off generator power, all the lights blink. It will not print out a test page. I have tried turning it off and unplugging. Anything else to try?
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Dec 24, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
824
Points
11
Unplugg it and leave like that for 5mins then try it again.
Testimonial: "Fast solution that I would have never figured out on my own"
Why does my printer only print half of a page?
Let's start by trying this:
Unplug the printer power cord from the printer and the wall.
Turn off the PC.
Disconnect the USB cable from both ends.
Plug the printer back in and turn it on.
Now, can you print a self-test page from the printer?
Make sure there is unused, plain white paper loaded in the input tray.
On the product control panel, press and hold the Power button and the Cancel (X) button at the same time.
Release both buttons. The diagnostic page prints.
If that does not work, are there any blinking lights on the printer? This document might explain them: Blinking lights.
If the self-test page does print normally, reconnect the USB cable, turn the PC back on and try to print a Windows test page:
Click the Windows icon and then click Control Panel . The Control Panel opens in a new window.
Click Hardware and Sounds .
Click Printers . The Printers folder opens.
Right-click the printer icon in the Printers folder.
Click Properties . The printer Properties window opens.
In the General tab, click Print Test Page . The Windows Printer Test Page prints.
If you have problems printing from Windows, you can try some of the troubleshooting steps in this document:
Printer Prints Blank Paper.
Finally, you may have to uninstall and reinstall the print driver.
How to clean head HP 7260
HP Photosmart 7150 and 7260 printers
  1. Make sure plain paper is loaded into the In Tray.
  2. To perform the first level cartridge cleaning is a spit and wipe, press and hold the Power button while pressing the Cancel button twice, then release the Power button. The printer will generate a series of noises as it performs the cleaning.
  3. Print a test page from the computer.
  4. Once the cleaning has completed and the test page has printed, examine the test page. If the print is not clear and/or there are lines in the color bars, continue to Step 5.If the print quality is acceptable, disregard the subsequent steps.
  5. To perform a second level cartridge cleaning, press and hold the Power button while pressing the Cancel button twice. Release the Power button and press the Resume button. The printer will generate a series of noises as it performs the cleaning.
  6. Print a test page from the computer.
  7. Once the cartridge cleaning has completed and the test page has printed, examine the test page. If the print is not clear and/or there are lines in the color bars, continue to Step 8.If the print quality is acceptable disregard the subsequent steps.
  8. To perform a super clean, press and hold the Power button while pressing the Cancel button twice. Press the Resume button twice then release the Power button. The printer will generate a series of noises.
  9. Print a test page from the computer.
  10. Once the super clean has the completed and the test page has printed, examine the test page. If the print is not clear and/or there are lines in the color bars, continue to Step 11. If the print quality is acceptable disregard the subsequent step.
  11. To perform a pen nozzle test, press and hold the Power button while pressing the Cancel button eight times. Press the Resume button four times then release the Power button. The printer will generate a series of noises then print a page displaying a test pattern. If there are gaps in the printouts the cartridge(s) may need to be replaced.
Printing test page at startup
Hi Monica,
You should have replaced new ink cartridges recently and since from that the printer must be printing Alignment test sheet. It means that you have not completed the alignment test.
Please follow below step to complete the test
  1. Turn the printer OFF and then ON, allow the printer to print the test page.
  2. Place the test page correctly on the scanner flatbed and press the scan button.
  3. Now the printer ON light will start blinking.
  4. Wait until the power light stops flashing.
  5. Now the test is complete and test the printer again by powering off and on.
Regards
Riztech
If this solution is helpful,kindly vote 'thumbs up' and testimonial.
I have Windows 7, I have a 5p (was just given) and the test page will not print. The green light at the bottom is continuously blinking. Suggestions?
bottom light blinking means it is receiving data try to unhook cable power cycle and try test print with data cable unhooked if you wait should error out if does not print
1helpful
Hp printer power light keeps blinking -- wont print any document
Turn both your printer and computer off then after a few minutes turn back on. This should cancel the print job.
15helpful
2answers
Hp d1460 wont print test page,wont print from wordpad in windows xp home
1.Turn the printer on
2.Press and Hold down the Power Button.
3. While Holding Down the Power Button, open and Shut the lid of the printer four times.
4.Release the Power button. The self-test prints.
Power Light Continues to blink.
if you are having issues after installing the new cartridges , then perform the following steps.
unplug the power adapter and remove both the cartridges and then power on the printer , look for the power light. if it does not blink then .
install the black cartridge first and then try to print , if it prints fine its ok. then remove the black cartridge and then put the color one in and then try printing or copying .
if it doesnot print with any either black/ color then you have to replace that particular caratridge..
lemme know once u r done....
2answers
Hp deskjet f380
I have experienced this before...
Disconnect the printer and remove the installed drivers, that is to remove the virus-infected file or a corrupt printer driver.
Now re-install the printer and the driver.
Fixya me on this one...
Norman Weimar
Norman Weimar
k24674
