Question about KitchenAid KEMC377K Convection / Microwave Oven
I have pluged in the temperature probe into the wall of the oven as well as inside the turkey. Now what..where do I see the actual temperature of the meat?
  • KitchenAid Master
  • 9,174 Answers
You can download owner's manuals and installation instructions for several brands (including Amana, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Posted on Dec 26, 2009
6ya staff
SOURCE:
The microwave displays F-6 and won't stop unless it's unplugged. Needless to say, it can't be used.
F6
Shorted temperature probe
This code will occur if temp. probe is detected as shorted
continuously over 5 seconds.
Replace temperature probe. part no 29 Thermostat
Part Number: AP3038826 made by WHIRLPOOL
The above part and all other parts of your model can be foundin the link
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=260444&diagram_id=28263369#d28263369
Jan 01, 2011 | Whirlpool MH7140XF Microwave Oven
I HAVE A DCS OVEN AND I USED THE SELF CLEANER ON IT ON SUNDAY NIGHT. WHEN I WOKE UP ON MONDAY MORNING THE CLEANING LIGHT WAS STILL ON EVEN THOUGH THE OVEN WAS COOLED DOWN. WHEN IT WOULDNT OPEN, I USED A...
Hi.
The Oven getting lock after self cleaning is not uncommon.
That is caused by the high temperature reached on self cleaning, that can jam the control board or damage the door lock or the temperature probe.
Try first tripping circuit breaker or disconnecting power cord for five minutes.
After restarting try the oven.
If the oven still does not work, then hold down the cancel button for ten seconds.
If still no luck, then the oven is faulty in consequence of the extreme temperature reached in self cleaning.
If the Oven has regular display, then faulty part is usually the temperature probe.
If oven has no display, then the control board may had been damaged.
I can understand what problems a faulty oven can be in this moment.
Try first the reset, if that does not work, ring the number listed at the end of the owners manual to see if today any technician is available.
A local technician could easily put back the oven to work, replacing the probe, the point is that it will be difficult to find a technician right now.
Let me know if the reset works.
Regards.
Nov 24, 2009 | Microwave Ovens
I'm getting an F3 fault code on my Maytag Mod. # CWG3600AAB. Everything points to replace the temperature sensor probe. With electrical off I have the oven pulled out but the wiring\harnesss of the temp...
Your temperature sensor has failed. You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Sep 08, 2009 | Microwave Ovens
I have a frididare oven ple8389echthe top works the oven is giving me an f30 error what do i do
F30 is effectively a faulty temp probe.
The temp probe must be tested before replacement.
Testing is done using a mutimeter set on Ohms to read impedance on the temp probe terminals If reading resistance at room temperature returns less than 500 ohms, then replace the Sensor Probe.
If reading is more than 500 Ohms , then check or shorted Sensor Probe harness and eventually replace the wiring harness.
Model PLE8389ECH did not return anything, if model is PLES389ECH then here is the sensor probe :
Here is the probe for PLES389ECH : PS820208 for $39.
It is Part 37 on the left in the diagram below:
If my solution had been helpful, then please do not forget to accept the solution.
Thanks.
G.
Jul 05, 2009 | Microwave Ovens
The oven will turn on and get warm (not up to set temp)not as hot as it should. I no longer hear the forced air noise from the fan/blower from the back of the oven? It will not cook food, in the time frame...
is your power setting up allthe way (10) is it a convection oven also? microwaves dont usualy have a temp. setting unless there is a probe pluged in inside oven to a jack on inside wall of microwave microwaves can also get old and lose power if so you can get cheep ones at wallmart
Jun 17, 2009 | Microwave Ovens
New GE Microwave JVM1750DM1BB with F4 error in Sensor cooking
GE
Microwave Fault Codes Failure
Code
Condition Check/Repair F1 Open sensor, will occur below 190F of cavity temperature within 15 minutes after starting convection, combination or roast cook Check oven temperature sensor for continuity. Replace if zero or infinite ohms F2 Shorted thermal sensor, will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking Check oven temperature sensor for continuity. Replace if zero or infinite ohms
Note: It will take a minimum of 5 minutes of convection run time before F1 or F2 code will be displayed if the thermal sensor is shorted or open. F3 Shorted key panel (touch pad), will occur if a shorted key panel is detected continuously over 60 seconds Replace key panel (touch pad) F4 Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds Replace humidity sensor F5 Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds Replace humidity sensor F6 Shorted temperature probe, will occur if temperature probe is detected as shorted continuously over 5 seconds Replace temperature probe ProbEe Open temperature probe, will occur if temperature probe is detected open, or not plugged into the receptacle If probe is plugged in and "ProbE" is on display check continuity of the probe with an ohm meter. If zero or infinite ohms, replace it
Feb 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Have a kitchenaid superba part no. 4450786A with the probe indicator beeping for a temperature to be set. Prior to beeping started just used microwave to warm food; didn't need or use probe. What is...
Put the probe in the oven and beeping stopped. Left it in overnight and next morning took the probe out and there was no beeping. Have not heard beeping all day. Don't know why this worked but it did.
LaMason
Oct 12, 2008 | Microwave Ovens
Looking for Temperature probe for JVM1190
Most any standard microwave temperature probe should work, from places such as Wal-Mart, Home Depot, Lowe's, etc.
Nov 21, 2007 | GE JVM1190 Microwave Oven
Amana Radarange Microwave/Convection over the stove
what is the model number of your radarange? it should be found inside the microwave on the rim.
Nov 21, 2007 | Microwave Ovens
Gas double oven--Roper
This code means you have a bad temperature sensor or thermal fuse, or a fault in the wiring harness to or from one of them.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 19, 2007 | Microwave Ovens
KitchenAid KEMC377K Convection / Microwave Oven Logo
312 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jaime Hernandez
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
