first of all you need to be draining the tub completely and removing any bath mats or items from inside. Fill the tub with hot water, ensuring that the jets are covered. You can use white vinegar, 2-3 cups of white vinegar directly to the water in the tub. Turn on the whirlpool system and run it for 15-20 minutes. While the jets are running, use a soft-bristled brush to scrub the jet openings and the interior walls of the tub. Drain the Tub: Refill the tub with clean water and run the jets again for another 10-15 minutes to rinse out any remaining cleaning solution. This should help. This is what I did with mine
No they do not here is a simple way to clean the jets and the piping.
Regular Jet Cleaning
To clean the entire whirlpool system and tub exterior, follow this process every month or more frequently if needed. Don't let dirt and grime build up or you'll have more scrubbing to do to get the tub clean.
Fill the tub with hot water, approximately an inch above the highest jet.
Make sure the water temperature reaches at least 140? F (60? C).
Add 1/2 cup of laundry detergent or the amount used to clean 1 load of laundry as recommended by the detergent manufacturer.
Run the jets for 15 minutes.
Drain the tub and refill with clean lukewarm water.
Run the jets for another 15 minutes.
Drain the bathtub.
Dry the tub completely by wiping it down with a clean towel.
The problem you are experiencing is common to many jetted bathtubs.It is a result of dried bathing water in the tub. There are a couple of solutions to resolve this ongoing problem.
Use your tub more frequently as the water will not have time to fester in the pipes.
Use a cleaning solution made for cleaning the pipes on jetted bathtubs once every three months.
You find Cleaning and Maintenance Products for jetted tubs at the following website. US Parts Center
Put white vinegar in the water and run it through your tub. Fill the tub to it's maximum running capacity, which is normally just above the jets, and pour a gallon of vinegar in the water with it. Let it run with the vinegar for about 20 minutes, then turn it off and let the vinegar sit in the jets for about 30 minutes. Then start up the jets again for about another 10 minutes and drain. Then run plan water through the jets for about 15 minutes, drain and that should do it. I would recommend doing this at least once every 2 months depending on your water type and how often you use the tub.
First find access to tub,by code there needs to be access to pump motor,either built into wall or various tubs front skirt is removeable.Fill tub and run to visibly see leak,sounds like bearing assembly gaskets are leaking on pump,could possibly be a jet connection,but if it only does while running its the pump or motor assembly.Hope that helps,in the future make sure water is always above suction intakes or can lead to premature burnout of pump
look on the back of the motor there should be a shaft that you can try to turn to spin free because something inside the pump is blocking it. rate me if this is helpful.
Sorry, the tub will have to pulled out to find out what is leaking so it can be fixed. There is just no other way UNLESS you can open up the wall on the blind side of the tube. (but its probably and exterior wall...if the house is vinyl sided, it can be done. If brick, you'll have to pull the tub). If you just wanted to convert to a tub only, maybe Bathfitters has an insert solution...
It sounds like the motor needs to be lubricated or there is debris keeping the impeller from turning without the help of a littl force. I would have a professional that deals with whirlpool tubs come and lube the motor.
