Weak coffee and pale crema.
If you get weak coffee from espresso machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check
if water is dripping right at the center of the filter, if it is
dripping on one side because the orifice is clogged, that can result in
weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure
that you are not leaving the machine brewing for a time that is too
long, and Italian coffee cup is very small, approximately one regular
shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This
are the trickiest ones, you need art and practice to get a good
espresso with a Moka, but when you learn, the result is better than
what you may get with an home electrical espresso maker.
The frame
on the hob must be not too strong, and the mixture coarse but well
pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
i know how to adjust the grind...it doesnt matter what the grind is set on....its on as fine as it will go and still grinds for at least 30 seconds for watery nasty coffee...it shouldnt grind that long regardless of the grind size...i realize its not a great machine but this is a problem it hasnt had before...i'm thinking that either it thinks there is more coffee in the dosing chamber than there really is, the burrs are dull, or there is just some computer/electronic malfunction going on.
