Good day,
You can go here to see the basic wiring setup of your terminals for the compressor along with the relay and overload.
http://www.jimdow.com/jimdow/sales/diagrams/refcopressorterm.jpg
L1 andL2 can be interchanged, since it is alternating current.
Basically, the overload is clipped to the body of the compressor, and is wired to the top center pin (common).
The relay, is pressed onto the R & S terminals. L1 or L2 can be used to connect to the overload terminal. The unused one is connected to the R side of the relay.
In addition, there is a run capacitor that is jumpered between R & S.
Actually it is an accessory to improve the effeciency of the compressor. It would run without it.
Hope this helps..
Thanks for using Fix Ya
Many times a freezer and/or refrigerator do not work right because of
a dirty condenser coil...there are also many other things that can go
wrong.
If
you are hearing a clicking or buzzing then check out the last two
tips.
If your refrigerator is running but warm, then...
Check
out these tips that I wrote about that... it is a great place to
start trouble shooting your unit...and something that you can do
rather then calling a repair person to do a simple thing for
you...
Refrigerator Condenser
Coil Cleaning
Refrigerator Repair
Refrigerator
Troubleshooting
Refrigerator Compressor
Refrigerator
Compressor
Start Capacitor and Start Relay
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
