Question about Coleman 10' X 10' Sundome Tent 9160K101
How to install batteries in coleman axis headlamp
Side panel comes out by turning (if you look on head strap, one of the ends says Key/battery. You can insert that into the side battery compartment and turn counter-clockwise). After you have that cover off, simply take something like your knife and pry it from behind the battery case and it will slide right out.
(O) is what you will see if you're looking down on it. The circle in the middle should have 3 tiny screws in it. Stick your knife between the O and the ) and pry the O out. Hopefully that makes sense. You could also just pop the battery cover off, and then hit the flashlight into your hand so that you knock the battery compartment loose. Then you don't have to pry anything. But that might damage the LED...probably not though.
Posted on Dec 28, 2009
SOURCE:
I am trying to find battery location for Coleman Model 5327A750
William, went to Coleman site, looks like you remove screws on bottom of lantern to access and change battery.
Check the attached links to your manual,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://r1.coleman.com/Manuals/5327.pdf
Rugged Rechargeable Family Size Lantern
Coleman Rugged Rechargeable Lantern Replacement Parts Flashlights...
Battery Buyer Batterybuyer com
Mar 06, 2016 | Coleman Camping, Backpacking & Hiking
Charge Time for 5312 Lantern Battery?
Charge time is 18hrs. If you left it on and it was flat, imediately charge for 40hrs.
heres the manual.
http://r1.coleman.com/Manuals/5312R.pdf
Feb 12, 2014 | Coleman Retro Rechargeable Battery Powered...
User's manual for coleman rechargeable lantern model # 5348-700
There are several options to buy replacement batteries for a Coleman rechargeable lantern, model 5348-700. I just picked up two new batteries from www.1000bulbs.com for $4.87 each plus shipping. ($20.99 for 2 with shipping!) Do a Google search for: ub645f1 6 volt - 4.5 ah - f1 terminal battery for other options
Jan 22, 2012 | Coleman Rugged Battery Powered Lantern...
I JUST bought the coleman mini led headlamp and i don't know how the batteries are supposed to go in. the back will not open and there were NO instructions.
TO INSTALL OR REPLACE BATTERIES
1. Rotate body of headlamp until lights are pointing down and battery cover tab is to the front.
2. Insert edge of buckle on headband or a coin under tab and twist to unlock and remove battery cover.
3. Install 3 "AAA" cell batteries in the correct orientation as shown on the battery housing. Make certain all 3 batteries are installed
correctly.
4. Replace battery cover by first inserting the tabs on the back of the battery cover under the back edge of the battery housing, and
then rotate down until battery cover snaps into locked position.
For the manual: http://www.coleman.com/coleman/images/pdf/4343-704.pdf
Feb 21, 2011 | Coleman 3AAA LED Headlamp
I can't seem to get the "small" screws off to put the batteries in!! Please Help!! Thanks:)
You don't remove the screws!!! Use the plastic 'key' that is in the headstrap to remove the cover (opposite side of the headlamp from the switch). Then shake the headlamp to allow the battery cartridge to slide out.
Dec 27, 2010 | Coleman 3AAA LED Headlamp
How to turn on Model No. 3000001019 Coleman headlamp. I got the batteries in but it does not go on. How do I turn it on?
Make SURE you have the batteries in the right way. If you have a battery turned around it won't work, plus you will likely bend the spring inside and then be unable to get the battery in the right way.
Dec 25, 2010 | Coleman 3AAA LED Headlamp
How do you install the batteries
If it is the same as the Coleman headlamp I just bought, it claims to have a "easy slide out battery cartridge" On the strap there is a plastic key to unscrew the lid where the batteries are but this doesn't allow you to access them. When you bang the entire thing in your hand to make the cartridge slide out it may not come at first because it is stuck. I partially unscrewed one of the tiny screws on the top of the battery cartridge and pulled on it. This caused it to slide out of the headlamp and I could load it with batteries. I then rescrewed it in gently as its kind of fragile. After this I could get the cartridge in and out by simply tapping the light in my hand with the lid off. The light works great now. Since the screwdriver is so tiny that you need to do this, see if you have a eye-glass repair kit lying around. It may have the size you need.
Nov 07, 2010 | Coleman 3AAA LED Headlamp
I just bought the coleman Max mult-colored headlamp and i cant figure out how to put the three AAA batteries in
In the headstrap is a plastic 'key' that you use to remove the battery cover (opposite side of the headlamp from the switch). Once you remove the cover, you can shake the headlamp to let the battery cartridge slide out of the headlamp.
Pay close attention to which way the batteries go in--if you put a battery in the wrong way you can easily bend the springs inside!
Oct 26, 2010 | Coleman 3AAA LED Headlamp
Cant figure out how to take apart to replace bulb
More information is required in order to answer your question. However, the following link will take you to the Coleman website for battery powered lanterns. www.coleman.com/coleman/parts/product_category2.asp?category_id=170
Jul 19, 2010 | Coleman Rugged Battery Powered Lantern...
Coleman 10' X 10' Sundome Tent 9160K101 Logo
5,151 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
Vernon Taylor
john h
Thomas Perkins
Thomas Perkins
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
