GE WVSR1060A Top Load Washer Logo
Posted on Dec 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Drum on washer leaking, how do I get to it? - GE WVSR1060A Top Load Washer
jimorris77
Level 3:
  • Master 411 Answers
  • Posted on Dec 24, 2009
jimorris77
Master
Level 3:
Answers
411
Questions
0
Helped
96510
Points
1202
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the machine ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and just happened to see that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video on youtube which showed me how to take my machine apart. This video (direct drive washer repair) made it possible for me to do my own repair. You probably don't have any idea of the wonderful help you can get from youtube videos. Your first stop should be at youtube. Just search for the help you need. You could search for "clothes dryer repair" or "clothes washer repair" or "dishwasher repair". If you are not able to view and/or download the videos, or after you've seen all you want to see, I suggest you go directly to www.applianceaid.com where they have very good step by step trouble shooting and repair information on washers, dryers. and dishwashers as well as other appliances. Another excellent site is www.acmehowto.com If you have a direct drive top load washer and need help taking it apart these youtube videos are wonderful help. I was so impressed with them that when I saw all these people needing help, I wanted to tell them about the videos. If you look at the back of your top load washer and the panel is solid (no small inspection plate to remove, which would indicate you have a v-belt drive) chances are you have a direct drive and this video (direct drive washer repair) is just what you need. After you've seen all the appropiate videos, or if you have a belt drive washer, you will probably still need help in determining what the trouble is and how to fix it. I suggest you go to www.applianceaid.com where they have very good trouble shooting and repair nformation on most washers and dryers, dishwashers and many other household appliances. I think you'll find what you need there. Another excellent site for DIY help is www.acmehowto.com Don't worry about the timer on a washer, they hardly ever go bad. I realize I haven't solved your problem for you, but I hope I have sent you where you can get help to solve the problem. Good luck with it.
Washer leaks on floor from drum top while centrifugating
Good Morning Andres,
I see that you are having trouble with your Frigidaire laundry center, model# FEX831F, and the washer leaking water from the drum top onto the floor. It could possibly be that your washer door is either not closed all the way or is not sealing properly. I suggest checking to make sure that the door is closed all the way. If it is, I would check the seal, and see if there anything that might be damaged and allowing water to leak from the drum top. If you are unable to find anything that might be allowing the water to leak out, I suggest contacting your local authorized technician. They will be able to diagnose your appliance and see why you are having water leak from the drum top. Hope this is helpful.
-Best Regards-
WP
My Samsung is leaking water under the washer.Its leaking from under where the drum is.It fault gasket leak from the drum.The washer is one year and 4 month old.Is there a guarantee on it.Samsung say...
I never heard of a washer gasket of drum....Just try to look closer new as your machine is usually something that cld be easily sorted, check if pipes aren' loose or broken.
Water leaking from bottom of washer between the washer and petestal
Hi
The water leaking on floor can be a serious issue as this may cause the inside parts to malfunction or in some cases rusting of the body. To check where exactly it is leaking; inspect the leak while it is running. After the cycle is complete quickly turn off the power, lie down the machine on left/right side and check from where the water is leaking. If it is the hose or drain pump then check whether hose is connected firmly and is not cut. If it not the hose/pump inspect if the leak is on the drum corner or anywhere on the upper side of the drum. If it is on upper side that means the drum is cracked and it is a costly affair. However, if it is leaking from the circumference then it is due to transmission seal. To replace the transmission seal you'll need to disassemble the washer and the drum assembly. Please post back in case of any issues. Hope this helps... Please post back if you need more information.
Daniel
Roper washer is leaking above the motor.
Main gasket and seal on the bottom of the machine. You will need to replace the drum gasket and the bearing seal.
Internal leak on a kenmore top load washer
Yes, very likely is a bad water inlet valve allowing water to leak past it into the drum. Really not a difficult repair with a little help.
Go here for:
Kenmore Washing Machine Parts
RepairClinic.com
appliance parts, help & more
Maytag Washer leaking from front
If I remember correctly, you need to remove the drum to get at the bolt that you are talking about. There is a rubber washer that provides the seal. The locking collar on the hub is Left hand thread. If you work at it you can get it loose.
1helpful
Water leaking from my whirlpool frontload washer
open the door and check between the drum and door frame. There is a large rubber bladder completely surrounding the drum. Pushing the drum further back into the machine will let you see the entire thing and unfold it. These often get small laundry like socks stuck there as well as sharp objects like nails. You may have a tear in it which will leak like that. Replacement parts run about $70.00.
Top GE Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Virgil Watts
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
