Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Posted on Dec 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I faced this problem in my system.....This copy of Windows did not pass genuine validation.what means this sentence obove? and what meas too by this sentence.downThe product key found on this computer is a Volume License Key (VLK) that has been blocked....hlep me please to get...
Anonymous
Level 2:
New Friend:
  • Expert 95 Answers
  • Posted on Dec 24, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
95
Questions
0
Helped
41808
Points
296
The license key of ur Xp is not legal ur got to pay for the new license key via microsoft
2answers
I faced this problem in my system..... This copy of Windows did not pass genuine validation. what means this sentence obove and how to solve it?
Hi, you have to activate your windows once again, in order to run genuine windows. To do that either you have to purchase the windows key or activate it via a tool.
Read here the full process -
Activate windows via key
Y9ou may be a victim of software counteriting. This copy of windows did not pass genuine windows validation.
This means that your license copy is pirated. If recently purchased and installed you should report it back to vendor or if this one is just a new message after Operating system being in use from last few days then you should report it to Microsoft support ( if licensed copy ). Follow the link to check for Genuine Validation
http://www.microsoft.com/genuine/default.aspx?displaylang=en
Just downloaded internet explorer 8
i think your windows is not genuine (original) so and it automatically update your windows so thats why it gives you that messege. its beeter to remove the WGAnotifier to your system to stppoed this.
4answers
Hey Hi Shalin,
I believe u r not using the key that either is tagged with a branded system or on the cover of the WINDOWS XP DISK. Here, by Volume License Key (VLK) is meant that the PRODUCT KEY FOR WINDOWS XP has been used number of times and after that MICROSOFT has blocked it and it will work with the Computer from which it was registered.. In order to stop piracy MICROSOFT has done that, when a pirated version of windows is used online MICROSOFT record few details like MAK, Hard Drive Serial Number and few important details regarding the pc and on finding the PRODUCT KEY fraud they install WINDOWS GENUINE ADVANTAGE PLUG-IN into the system... If u have paid for the LICENSED VERSION of windows xp then contact the support person from where u bought it otherwise there are ways to remove it as well for that u can follow these steps....
FOR WINDOWS XP
THERE ARE NUMBER OF METHODS BUT FOR YOU THESE 2 METHODS ARE GOOD
1) METHOD:-
TRY SYSTEM RESTORE.
2) METHOD:-
2.1) LAUNCH WINDOWS TASK MANAGER.
2.2) End wgatray.exe Process In Task Manager.
2.3) Restart System In Safe Mode.
2.4) Delete wgatray.exe from c:WindowsSystem32.
2.5)
Delete wgatray.exe from c:WindowsSystem32dllcache.
2.6) Launch RegEdit.
2.7) Browse the following key HKEY_LOCALMACHINESOFTWAREMICROSOFTWINDOWSNTCurrentVersionWinlogonNotify.
2.8) Delete The Folder "WgaLogon" and all of its component.
2.9 ) Reboot System.
3.0) BE HAPPY NOW.... AND NEVER EVER INSTALL WINDOWS GENUINEADVANTAGE NOTIFICATION IN WINDOWS UPDATE OTHERWISE YOU HAVE TO REPEATTHE DAMN PROCESS AGAIN.
IN ORDER TO THAT FOLLOW THIS
START
--> CONTROL PANEL--> AUTOMATIC UPDATES --> CHOOSE THE OPTION """"""""""""Notify me but don't automatically download or install them"""""""""""
When u use this option whenever your system detects any new WINDOWSUPDATE choose the updates which u want to install... DON'T INSTALLWINDOWS XP SERVICE PACK --3.
If this doesnt work then follow this
{THIS IS THE LINK http://www.wikihow.com/Remove-Windows-Genuine-Advantage-Notifications}
STEPS TO REMOVE WINDOWS GENUINE ADVANTAGE
  1. If you have only just installed Windows Genuine Advantagenotifications, simply using the system restore function will remove theprogram. Then refuse to accept the WGA update next time Windowsupdates... Otherwise, proceed as detailed below. (NOTE: If you try these steps while you are in "Safe Mode," step #8 is unnecessary).
  2. First Try the Following:
  3. - Open a CMD Line Window by Clicking on Start ==>Run ==> type CMD and Press OK.
  4. - Change Directory into the System32 Folder (Like Cd c:WindowsSystem32)
  5. - Open a notepad Window and type the following lines:
  6. taskkill -IM wgatray.exe
  7. del wgatray.exe
  8. del wgalogon.dll
  9. - Highlight and copy to the Clipboard the three lines above
  10. - now Paste the the contents of the Clipboard to the CMD Window
  11. This should kill the wgatray.exe Process from the Taskbar andimediately delete both files wgatray.exe and wgalogon.dll without theneed to to go through all steps bellow.
  12. If that does not work, then continue and follow the steps bellow
  13. Open System32 by either A or B of the following methods:
    • a) syst32runok.pngClick "Start", "Run", then type-in "System32". Click "Okay".
    • b) Find System32 manually by clicking "Start" > "My Computer"> "(X:)" (Replacing "X" with the drive letter of the host ofWindows) > "Windows" > "System32".
  14. In "System32", go to "Tools" > "Folder options" > click onthe tab, "View" > Uncheck "Hide extensions for known file types". Now you can begin...
  15. Check to make sure the window that comes up has a full screen ofvarious files. The files are in alphabetical order, which makes iteasier to locate the specific file.
  16. wgarenme.pngFind "WgaLogon.dll" and rename it "WgaLogon.dll.bak".
  17. Create an empty copy of WgaLogon.dll:
    • crtebnkwga.pngRight click on a blank space in System32 and select "New" > "Text Document".
    • Leave the text document empty and label it "WgaLogon.dll". Press Enter (on your keyboard).
    • wgawanignoyeas.pngYou may get a warning from the above step that says, "If you change a file name extension, the file may become unusable. Are you sure you want to change it?". Click "Yes" on this warning.
  18. Be ready to complete the next two steps very quickly! Find"WgaTray.exe" in "System32" and delete it. You will then have 5 secondsto find "WgaTray.exe" in the Task Manager (the next step). NOTE: If you remove the files mentioned above while you are in "Safe Mode," step #8 is unnecessary.
  19. tskenproctb.pngImmediately open Task Manager. You can do this by pressing the Ctrl,Shift, and Esc keys simultaneously, pressing the Ctrl, Alt, and Deletekeys simultaneously, or right clicking the Taskbar and selecting "TaskManager". Click on the process tab and click end process when"WgaTray.exe" is selected. Note: If you take longer, do not panic!All that will happen is that "WgaTray.exe" will keep reapearing in theprocesses list (i.e. you won't be able to delete it as required). Toremove the notifications after this, return to system32. You will findtwo files:"WgaLogon.dll.bak" (the one you renamed) and an ApplicationExtension (0KB) called "WgaLogon.dll". Delete the ApplicationExtension, rename "WgaLogon.dll.bak" to "WgaLogon.dll" and repeat thesteps from the fifth one onwards (at a greater speed!!).
  20. Restart your computer once you have finished. All the notification messages should be gone.
Every time I start my computer, the "This copy of Windows did not pass genuine validation" appears on my scren and unable to disappear
it is illegal to remove it. your copy of windows did not pass genuine validation meaning your copy of windows is not a valid copy of windows. its a cracked version. if you want to remove it you should buy a genuine copy of windows
2answers
The main issue is that your windows got expire and its time to activate it once again. It needs to be activated always in order to stay genuine.
5helpful
2answers
Software counterfeiting,did not pass genuine windows validation
message appearing on the screen that you may be a victim of software counterfeiting.this copy of windows did not pass geneuine windows validation. hiiii this is msg displayed on my screen
software counterfeiting,did not pass genuine windows validation problem,
2answers
Genuine validation
you need a valid COA(certificate of authenticity). means you need a valid product key for your operating system. Once you have it, it will solve your problem.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
