Question - can you till the code 4 veltech tv two operate sky remote - 2H. ... if you will rate me in a positive fashion before you close this page, the system will ...
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state ‘Sky rev’ (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control. Version 4: May 2001 (Sky+ introduced) Codes are 0065, or 0405,or 0037
Version 6: March 2004 Code are 0065, or 0405, or 0037
Version 8: January 2006 (includes all current Sky+HD remote controls) Code are 1293, or 1206, or 0206 Programming the remote control To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings above (Use the 4 digit codes), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote. If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes above or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code
Go to http://sky.uebv.com and enter:
1. Your Sky+ Remote version (Inside the battery compartment)
2. Your TV Manufacturer
3. Your TV Model
Click on <GET MY CODE> and hope.
Got an answer of 1293 for LG Model 37LH3000 but not tried it yet.
try your volume button if this works press the SELECT button to save the code. if not press TV and then try the volume again. repeat this step until the volume works. then remember to press the select button to save the code
the remote i had was rev 6 control and i tried every number going but no luck. i then ordered new remote control which is rev 8(you can find this when you open the battery lid) and i typed in 0206 and it worked(bingo).
I have found out the solution to this problem.Don t listen to Sky ,just buy your self a latest" series 8 sky plus remote control "and at about £12.00 0n ebay.Then all you do is phone LG customer services with you TV model number.If you have any probs email me at [email protected].
