Question about Samsung HLR5667W 56" Rear Projection HDTV
Makes buzzing sound and no picture lamp? - Samsung HLR5667W 56" Rear Projection HDTV
    New Friend:
37" polaroid TV model FLM373B - no picture and loud "buzz" for several minutes then picture will begin showing and buzz eventually goes away. What do I do? Repair? HELP... driving me CRZY!!!
Posted on Jan 12, 2010
  • Samsung Master
  • 5,138 Answers
Buzzing sound is the Color Wheel # BP96-00250A $83.25 Encompass Parts has them in stock 1-800-638-3328 and for Lamp Call FOX 1-800-227-5369 I got my Lamp off of E-Bay $85.00 I have the Same TV.
Posted on Dec 24, 2009
SOURCE:
No picture.... makes a buzzing / small bell sound on and off...it has sound but after a minute it turns itself off.
This is a projection tv correct?Yes?The old projection lamp has not been replaced like 1 1/2 or 2 years?Tv in used daily like 4 or 5 hours everydays?Yes?Tv make buzzing sound and bell sound on and off.The tv on the frame the word "LAMP" the LED light indication it is flashing or stay on lit?Yes?Then the tv projection lamp life have ended,tv require a new projection lamp.
Aug 10, 2011 | Mitsubishi WD-60735 Projection Television
I have a hd61lpw165 big screen tv that makes a loud buzzing sound as soon a it goes on with no picture.
sounds like the lamp or ballast, check the lamp first to see if good, then if good, then probably the ballast is bad, but I think the sound or buzzing is coming from the ballast, so it's should be good.
Mar 04, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
For the last couple of months there's a buzzing sound when the TV is powering up. A couple of times I list picture during a show but, I powered down and the picture came back. Now, I don't even get a...
You could have 2 things Color Wheel and Lamp needs to be replaced Color wheel is what Making buzzing sound,
Go to Encompass Parts Distribution 1-800-638-3328
Type in your Model # they will have list of Parts/Supplies
Oct 05, 2010 | Samsung HL-R6167W 61" HDTV
My samsung 42 inch hdtv is making a buzzing noise
First. The whirring or buzzing sound you hear is the Color Wheel and it needs to be replaced. Second, since I do not know when and if the original lamp has been replaced it is a good idea to replaced the lamp. The bad Color Wheel is the one causing the set to shut down.
Apr 04, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
Mitsubishi WD-65733 no picture, electrical buzzes in series
What it sound's like is that the lamp ballast is the problem. Buzzing sounds like when the power is first brought to the ballast it has to ramp up the voltage to get the lamp to light, then the voltage drops back down when the lamp is lit. Sounds like the lamp ballast isn't ramping up the voltage the way it should. May have to replace it. A good service shop would be able to do this for you.
Blessings,
A/V Media Guy
Nov 20, 2009 | Mitsubishi WD-65733 65" HDTV
No picture and buzzing sound on Sony XBR Wega
Is the bulb light flashing ? - Sony's bulb light is very accurate in telling you if the bulb is bad. The buzzing sound could be from the balist trying to strike the lamp. You also may want to open the lamp door and see if the bulb is shattered.
Aug 01, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Light engine problem?
sounds like your ballast is bad let me know your model number and I should be able to help you
Apr 11, 2008 | Mitsubishi WD-52627 52" Television
Buzzing noise, sound but no picture
It sounds as if the lamp needs to be replaced. The buzzing sound you hear is the ballast attemting to fire the lamp.
Oct 20, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
No picture or sound after replacing lamp
Possible bad color wheel...
Pull the lamp out & look inside where the lamp sends the light-
does the color wheel look defective? If so,replace it.
Or, the lamp ballast may be bad.After that,usually replace
complete engine.
Oct 19, 2007 | Samsung HL-R6167W 61" HDTV
Samsung HLR5667W 56" Rear Projection HDTV Logo
329 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
