Televison & Video Logo
Posted on Jan 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TV makes chirping noise, won't turn on!
Philips Smart Series 32 inch TV won't come on, press power button, nothing, light won't even come on, chirping noise when plugged in. TV is 7 years old
  • Oscar52 Jan 26, 2008
    By the way this is not a projection TV. Anyway you asked for a chassis number: 32M800 7603. Thank you so much for your help, I live 60 miles from the nearest repair shop, and 17 miles of that is nasty dirt road, so some information ahead would be helpful before I drag this TV to town, thanks again!!
  • Anonymous Mar 27, 2014
    Constant chirping
Sonny Berry
Level 3:
  • Master 8,617 Answers
  • Posted on Jan 25, 2008
Sonny Berry
Master
Level 3:
Answers
8617
Questions
Helped
1721651
Points
23750
That usually means a problem in the start up or deflection circuits. Diode, Horizontal ouput or driver transformer. What Chassis is this set, and I will be ableto give you some better information. Rca , GE and phillips need to be diagnosedwith the chassis number. Let me know the chassis.
  • Sonny Berry
    Sonny Berry Jan 26, 2008
    That is usually a symptom of a defective flyback or horizontal deflection component failure. This usually is around 100 to 150 in repair cost, However that depends where you have it serviced. You may wish to call and explain your symptoms most reputable shops will recognize the problem and give you a ball park estimate. Hope this helps.
Have a samsung 2011 samsung smart tv 32 inch. The tv automatically switches on and off intermittently and won’t respond to remote control
Has the power button on the TV been used often or not? If so it could be worn out/stuck and the two button leads making unwanted contact.
Samsung 32 inch smart tv 2011 switches on and off automically. Remote control won’t respond to the tv
My tv wont turn on when i press the power button on the tv ?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit.Contact any service technician.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
My phylips tv screen is zoomed after some time now it is not showing pitcher and turn of
The main digital processor board has the fault. In rare occasions, a software update might make this right. Contact the nearest authorized service center for Philips. Check this link too.
1helpful
Can't find install code for philips magnavox smart series plus
Universal remote codes for Philips Magnavox TV are: 0062 0204 0207 0183 0226 0288
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Tv won't turn on at all
no remote but tv was working with front power key? unplug from ac outlet and plug back and listen for any type of indication (noise or chirp) that something energizes inside if theres nothing then suspect a power supply problem, main fuse blown, shorted low volt rectifiers other components could be at fault.
Beeping noise when I turn on my TV
www.TvRepairKits.com just added a kit for the "chirping set" problem.
Hope this helps,
6helpful
8answers
Model F27650 RCA Entertainment Series
I have a RCA Entertainment Series 32' Model Number F32650Y01E024C226E just stopped working. no picture, just a chirping loud noise that came from the back of the tv.
Any suggestions?
2helpful
2answers
F32650 Chirping No Power On
Replace IHVT aka flyback xformer part #257805.
2helpful
No pic/sound
If you dont here anything then it sounds like the switching power supply or the horizontal output circuits not starting up. this requires troubleshooting with a variac, as well as maybe a scope. If your not trained to work on HI Voltage circuits you should seek assistance with this repair. Theres HI voltage inside these sets even after they are unplugged for a while. sorry i couldnt be of more assistance.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
