Its actually easier to do it all manually:
7. How do I transfer pictures from my Mustek camera to a computer? Use the USB cable provided in the package to connect your camera to a computer. Please first set the USB mode of video camera into "Mass Storage" option on the camera's LCD screen and press OK. Follow the instructions below to complete the process: a) Power on and press menu button to enter "Setup". b) Press the up / down button to select "USB Mode". c) Press the right button for 2 options: "Mass storage"; "PC camera". And select "PC CAM" and press "OK" Note: Make sure you connect to your computer (NOT to a USB hub).
Go to MY COMPUTER.
Double-click REMOVABLE DISK drive.
Double-click DCIM folder.
Double-click 100Media folder.
Click EDIT then choose SELECT ALL. (All files are highlighted after clicking SELECT ALL).
Hi there, in first replace or check USB cable( it may be have short circuit or is torn off.) If you use OS Windows98 need install driver, if WindowsXP not install any driver, if you install driver in WindowsXP, removed it. For viewing pictures install Blaze Video Magic and/or Ulead Photo Express. Read owner's manual, page 40 4.2 Connecting to computer. Manual and driver for Win98 you can get from http://www.mysilvercrest.de/en/artikel.php?a=93&av=2 SilverCrest DV77 is full similar Mustek DV520T. Cheers.
heyii check in your menu of your cam,may be you will find an option for connecting to pc through..and there select 'mass storage'..,then connect your cam with the pc and it will detect the memory in sometym and then you can access all the data.. :)
OK! I TAKE IT YOU DON'T HAVE THE MANUAL FOR YOUR CAMERA? WELL, AFTER MUCH! HUNTING I FOUND A SITE FOR THE MANUAL FOR THIS CAMERA THAT SHOULD GIVE YOU ALL THE INFORMATION YOU NEED ON YOUR CAMERA. IF YOU NEED MORE HELP, REPLY TO: ARCLIGHT 1217. IF YOU FIND THIS HELPFUL, PLEASE VOTE! THANKS! GOOD LUCK!
Hi there, in first replace or check USB cable( it may be have short circuit or is torn off.)If you use OS Windows98 need install driver, ifWindowsXP not install any driver, if you install driver in WindowsXP, removed it. For viewing pictures needed installBlaze Video Magic and/or Ulead Photo Express. Read owner's manual, page 40 4.2 Connecting to computer. Manual and driver for Win98 you can get from http://www.mysilvercrest.de/en/artikel.php?a=93&av=2 SilverCrest DV77 is full similar Mustek DV520T. Cheers.
Hi there, in first replace or check USB cable( it may be have short circuit or is torn off.)If you use OS Windows98 need install driver, if WindowsXP not install any driver, if you install driver in WindowsXP, removed it. For viewing pictures neededinstallBlaze Video Magic and/or Ulead Photo Express. Read owner's manual, page 40 4.2 Connecting to computer. Manual and driver for Win98 you can get from http://www.mysilvercrest.de/en/artikel.php?a=93&av=2 SilverCrest DV77 is full similar Mustek DV520T. Cheers.
