Here this worked on mine read the ansewer part on this page
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Sony-Trinitron-KV-32V42.htm
How do I do this? I have the same problem but there is no "timer" button on my remote, I only see a "sleep" button but because the screen never comes on, I can't see how to set timer to 00
Pls set on timer function on remot canrol menu button on timer off timer is "00"
SOURCE: my sony wega model KV32HS420 tv wont turn on.The
I have a 60" Sony Wega LCD projection...not sure if it will work for your model, but ours would not turn on this morning and was blinking the 3 light error code. Which indicated that the lamp cover was not on. The lamp cover was on, but when you remove the lamp cover there is a small metal piece below where the screw goes to tighten the cover on. That piece needs to be pushed in so the sensor will not go off. This saved us potentially many hundreds of $$ in calling a repair person which is what all forums and threads suggested we do. Hope this helps.
