Question about Rotel RX-965 Receiver
"pop noise" on speakers when turning off receiver
Hi all, I have Rotel RX965 everything goes well until I'm turning it off.
When I turn off the receiver, the speakers making "pop noise" but only the center and the surround speakers. I'm sure it can damage the speakers for the long term.
Now, the technician said it is a problem with the digital card and he can replace some parts and fix it. The problem is it cost 130$. Before I'm saying yes, I wonder if there is any reasonable workaround which can help me fix it myself and save the money. Please help.
Thanks in advance
2 Suggested Answers
SOURCE:
SOURCE: Rotel RX-800
I have an RX 600 - which has just gone 'phut' - which is how I came today to find this website ! I once had your speaker problem but eventually tracked it down to a bad connection of the speaker cable into the rear of the Receiver. Plastic sheathing and dust was partly in the way. Strip off a bit more plastic to expose fresh bright wire, and remake secure tug-proof connection before you try anything else. Oh, and while you doing it, do the others as well !
Posted on Sep 11, 2008
Makes large thumping/chirping noise when turned on. Its not even connected to the receiver
Since you have said the speakers make this sound when "turned on", I'm going to assume there's some form of power amplifier attached (internal, external or otherwise). Based on the minimal information provided here, this simply sounds like the normal reaction of a speaker when the amplifier is turned on. In short, an audio speaker is a type of "transducer" and when power is applied (thru some form of amplifier), the cone reacts to the power surge and causes a thump, pop or other noise. Turn on your TV for example and you'll usually hear a small pop from the speakers...and a larger/more powerful amplifier is likely to make a louder noise. Without further information, in most cases this is quite normal.
Assuming there is an external power amplifier, my advice would be to turn the volume on the amp (regardless of whether there's a receiver connected) to 0 before turning the power on. If it still makes such a noise, it's possible the volume control of the amp may require cleaning.
Good Luck!
Apr 01, 2016 | Audio Players & Recorders
When I turn my receiver on it makes loud popping noises from speakers. I repeat turning it off and on until it doesn't have the popping noises and then everything runs normal.
Its likely a dirty contact on safety relays or volume track.
Remove power and rotate volume min to max 5or 6 times.
Or it needs safety relay contacts cleaning/repairing or ensure the volume is turned to bottom before you end up popping a cone on your speakers.
Nov 18, 2014 | Audio Players & Recorders
HALLO I HAVE A ROTEL RA 9858X AND AGTER PLAYING FOR A FEW MINUTES I LOSE THE RIGHT SPEAKER CHANEL
Try interchanging the speakers. If the right channel works, you have a problem with your speaker.
Jun 14, 2014 | Rotel Audio Players & Recorders
Speakers are popping
you may have a bad cord to your speaker or a bad rca cord ive had some what the same thing it turned out too be a bad groung on the rca cord
Nov 29, 2009 | Audio Players & Recorders
Rotel Receiver RX-950 AX popped and then quit
there would be life in the old girl it just depends how much you love her and how much you are willing to spend to get her fixed ?? some old rotels are still fetching good money so it might be worthwhile getting a quote
May 26, 2009 | Rotel RX-950AX Receiver
Static noise from Front Left Speaker
It would probably be with the speaker. That is easily checked by simply unhooking the speaker and running the test again.
Jan 15, 2009 | Yamaha RX-V661 Receiver
Rotel PReamp, Can I directly Connect my powered speakers to the output
Based on your post, the pre-amp is doing its job. What might be the mismatch would be the powered speaker system plugged into the output of the Rotel. Depending on what the "powered speaker system" is, it might be that it is a low impedance such as those used in computers whereas the Rotel requires high impedance to be connected to its output. What could be tried is to connect a regular amp or receiver to the Rotel.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 05, 2008 | Nakamichi AV-7 Receiver
Rotel RMB-1095 Power Amplifier Problem
Sounds like wiring problems. Unhook everything, then get owners manual for proper instruction
Apr 13, 2008 | Rotel RMB-1095 Power Amplifier
Rotel RX-800
Nov 26, 2007 | Rotel Audio Players & Recorders
Rotel RX-965 Receiver Logo
211 people viewed this question
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
