Sony VAIO VGC-RA830G (27242667815) PC Desktop Logo
Posted on Dec 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i make a recovery disk for the vaio vgc-ra830g pc?
  • justfaces Dec 25, 2009
    Previously I had a problem with a VGC-RA830G Sony Vaio which locked up while I was playing a game. Your suggestion was to unplug the CPU, clean out any dust and give it 1/2 hour. I did all of this and it worked. Unfortunately, the situation has occured again, after I upgraded to Explore 7 (?) and had to reboot the system. The VAIO image will pop up ad if I hit the F10 button , the blue screen will come up and tell me the hard drives are ok , but the C-MOS is "wrong". the icons on the dest top will pop up after about tem minutes. any ideas?
Ekse
Level 3:
  • Sony Master 13,435 Answers
  • Posted on Dec 23, 2009
Ekse
Sony Master
Level 3:
Answers
13435
Questions
82
Helped
3983080
Points
38023
Hello again,
Sony sells the recovery media if you require it.
https://servicesales.sel.sony.com/ecom/accessories/web/categorySearch.do?operation=subCategorySearch&subCategory=109&category=3&subCategoryName=Recovery%20CD&categoryName=Computer
if the link doesn't work copy it completely to your addressbar and press enter.
If your machine works and you can use it, and you have the original stuff from sony still installed then you can most likely find the vaio recovery from your start menu.
1. close all extra programs that you don't need.
2. disconnect your internet
3. disconnect printers and other extra devices
4. From the Vaio Recovery wizard appliaction, in the vaio recovery window, under media nad recovery options, click to select Create recovery media kit.
5. click the next button
6. You have two choises for recovery media either one recordable CD and two recordable DVD's
OR
10 recordable CD's.
  • Ekse Dec 25, 2009
    Could you clarify what do you mean with CMOS is Wrong?
    10minutes for the start up sounds like you either have very low amount of ram in the computer and too many programs compared to that, or you might need to restore or do a fresh install to solve that issue.
I NEED THE RECOVERY SYSTEM DISKS
The operating system is normally stored within a hidden partition on the hard disk and if you do not have the recovery disk(s) you should be able to purchase a replacement set from the manufacturer.
1helpful
Sony won't finish the start up. Freezes at black
use system restore to restore your computer to a earlier time either you can use the disk that came with the computer or you could do it when you start the computer it should say press so and so buttons to enter the system recovery then use system restore to restore windows to a earlier time so it will start up and boot into windows after you do the system restore
Trying to use recovery disk for VGC-RB34G PC. Disk 1 will not start. Properties show it full but unknown file type. Disk 2 appears to be ok but will not operate without disk 1. How do I get factory...
Sometimes manufacturers use proprietary software to start their recovery disks and that perhaps is why the file type is unknown. You say that it will not start. Are you trying to run it from within windows or at start up. All of the recovery disks that I have worked with have to be started from the boot up. The computer has to be set to start up from CD. Try that and let us know what happens.
If you need help getting the computer to start from cd let us know and we will help you.
Can I copy system32\config from VAIO Recovery Disk
first go to command prompt with recovery console.
then type chkdsk /r
tehn press y
then restrt the copmuter then it fix the harddisk error.then it will be fine.
Mce gives a decoder error after reloading system
Problem resolved
after loading the system , place Recovery disk 1 which exhibits all the applications need to be recovered.
Thanks
essar
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
