Just open it up and have a look, could be some plastic parts of the tray has been bent by someone accidentally pushing it in when locked, or something might mess with sensors telling the unit what position the tray is in.
there are very tricky mechanical devices that detect when the trays are closed and in what position they are in
A gear or mechanical piece is not in correct order or not functioning properly and will need intense studying to determine which position they all should be in at door closed , laser mech. position , standby position
can you upload a photo of the inside of the cd mechanism?
The tray position switch is disconnected or bent from disassembly. I expect one plug wire is off when you put the unit back. The tray switch is mounted so the tray strikes the switch when fully in and fully out.
In Some Cases The Button May Be Stuck In Causeing It To Keep Pushing It Open In Other Cases The Arm May Just Be Stuck To Extending The Tray Out. I Recommend Seeking A Computer Technician If You Do Not Know Anything About Computer Componants
on the bottom under the dvd tray is a hole. inside the hole is a white plastic gear that opens the dvd tray. it is stamped with a phillips screwdriver depression. insert a phillips screwdriver and rotate to open tray/
