Lionel Trains Holiday Express G Gauge Train Set Logo
Posted on Dec 23, 2009
WE are trying to get our lionel holiday train going. Is there an on/off switch on the train? the part that goes on the track is lit up but when we puch the remote control with train on the track nothing happens. new batteries in remote. does remote button light up when working?
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Nov 23, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5640
Points
5
The train does not run in daylight.....when one places the remote over the engine protecting the senor from sun the engine will start 10seconds after the sounds...I was very disappointed that it would not run in daylight. I'm looking for a method to rewire the system to work in daylight....maybe bypassing the control card.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Dec 27, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1575
Points
There is no on/off switch. Remote will give no indication of working. Try putting engine and coal car only and try. I have had this train set for two years and the remote tends to work whenever it wants.
Have power to the track loco cab light turns on red bow lights up but train dosent move at all. No bell or ho ho and nothong on any of the other cars
Try new batteries in the controller Be sure they are in correct. The LED light should come on when it has power. Try moving closer to the train. Usually when the red light is flickering is when there is an engine problem. But here is the Manual just in case you did not have one. Also it has a number for lionel Service in there. Good luck. =) http://www.lionel.com/media/servicedocuments/60287110222501.pdf
Lionel g gauge wont run on track
I think you have solved the problem. Check all the wheels to be sure that they all turn. The locomotive isn't powerful enough to drag a car with a stuck wheel.
Looking for instructions for lionel fast track automatic switch
Try contacting the Lionel Service Department on
586 949 4100 or use their website contact service. Contact Lionel Trains
Check out these Lionel Customer Service Videos.
http://www.lionel.com/CustomerService/service-documents/video.cfm?documentID=6334
http://www.lionel.com/CustomerService/service-documents/video.cfm?documentID=6337
Holiday Tradition Express, engine tender not working. Contacted Lionel Trains, they have no replacement parts or service available.
Best bet is to search the internet for Lionel replacement parts. Try to include as much information in your search.
CANNOT GET THE UNCOUPLING TRACK SECTION TO WORK THRU TRACK POWER - WHAT IS PROPER WAY TO HOOK UP RED AND BLACK WIRES? LIONEL FASTRACK
Track power is not recommended for this uncoupler. Use an aux fixed supply of at least 10 to 13VAC for the supply. You have to move a jumper on the bottom of the track to do this. Then there will be four wires needed. Two for the aux power (hot and common) and the other two which go to the pushbutton switch.
Note: Same goes for Lionel FasTrack Remote switches. Run the switches from a 10 to 12 VAC aux supply. There is a jumper you remove on the bottom of the switch to connect an aux supply.
2answers
I bought the set last year of holiday lionel trains g replaced batteries, have light on remote and noise from engine but no movement? any ideas
If all cars are not properly on the track, the engine does not have enough power to pull the cars. Try with engine and coal car only to zero in on cause.
1helpful
2answers
The train is not responding to the remote.
I had a similar problem with my 11000 Holiday Tradition Express. I cleaned the track with an eraser (pencil-type) and then used a soft cloth to clean any possible residue. After doing this twice, my train is now running.
Top Lionel Crafts & Hobbies Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Carolyn Rogers
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
