Make sure you unplug the unit first. there should be screws at the base, in the back, or underneath the humidifier. Once you remove all the screws the cover should come off as one big piece. Careful when removing the cover, however, as there may be ground wires attached to it . Usually if you vacuum out the inside godd and around the copils that may help with performance. You can also buy a special acid that you can spray on and rinse off with water that removes alot of residue.
http://www.iallergy.com/product841/product_info.html
Also, Don't forget to pull the plug, shut the water valve and drain the unit. A unit with a water reservoir should be drained and cleaned with white vinegar, a mix of one part chlorine bleach to eight parts water or muriatic acid. Mist-type humidifiers also require regular cleaning to remove mineral deposits.
