Install games to Sony Ericsson W550i Cellular Phone????????
How to install games from PC to Sony ericsson w550i? Which file i hav to download from net?
And when I download the file to PC , and open it , it didnt ask me " do you want to install to your pc?"
how can I install jar file game to my mobile?
I keep my cell on" file transfer mode" Or shall i Keep on " PC Mode" ?
I want to download via Data cable only not thru WAP
When you insert your usb cable to your phone, is it give you phone and file transfer mode. If yes then reinstall pc suite. If no then your usb cable is defective or usb port to computer is properly connected.
Please if you have more any question then reply to this solution if your problem is solved then mark as answer.
Sorry but you cannot install .sis files on a W550i as they are symbian and the W550i does not support symbian, the W550i does support .jar files though.
1. Connect your W550i phone to your PC using the USB cable. 2. Use it in File transfer mode. 3. Go to it's Others folder on the Memory Stick that just appeared over at the My computer screen. (probably called PHONE_CARD or something similar). 4. Copy the .jar files from your PC to the Others folder on the phone's stick.
5. Disconnect your phone properly (safely remove hardware) and allow it to restart or return to Phone Mode.
6. Go to your files on your phone (File Manager) and go to Others. Select the file, click Install.
7. It'll ask where you want to install the file, either in the Applications folder or the Games folder.
Please let me know if this had helped you out. Please rate.
What Operating system do you use...First you have to download a PC Suite which will sync your computer and your cellphone. I will send you the link. Then Just follow the step by step instructions. Be sure to plug your cable as well. Please dont forget to rate me. Thanks!!! Heres the link:
http://www.sonyericsson.com/cws/corporate/support/products/softwaredownloads/w550i
6. They should appear in your games folder. Otherwise go to your files on your phone (File Manager) and go to Others. and open the files.
i not able to install gamesn in my mobile how to resolve this
