Sciphone i9+++ user manual needed to activate Java & apps
I need a user manual so that i can activate Java and learn how and where to download apps. Where do i download apps from for this phone...i'm assuming that itunes/iphone apps are not compatible.
hi, Download Some Sample Java Games For Your Sciphone
Step-by-Step installation of Java games onto your Sciphone :
1. Download one of the zipped .jar files on to your PC. 2. Connect a USB cable to the PC 3. Under My Computer find new removable disc (most likely will be E:) 4. Double-click on the disc icon -> it should open a window.-> setup a new folder :\java 5. Directly drag-and-drop one of the unzipped .jar files, like tanke.jar in the java folder. 6. Disconnect the USB cable - turn ON Sciphone i68+ Console - in the file manager- find the java folder - open it - select the tanke.jar - click the option and choiced the setup - click ok till finish. 7. After install complete,go to the home page, click the java icon on the home page, choiced the java file that already be installed, run it. 8, enjoy the game.
Ok you should be able to go into JAVA on you i9 phone and select OPTIONS and delete the chinese games. As for other apps, I have not been so successful in finding the ones that are like the apple phone but here is a site that has games for your phone www.getjar.com
The CECT i9 and i68+ have JAVA. Unfortunately, most of the free JAVA games out there, are designed for keypad input. You will have to look for specifically "touch screen" apps and games. And among those, not all of them will work. I am afraid it's going to be "trial and error" for a while.
As for HOW to load the JAVA apps and games on your CECT i9, here's how:
On your computer, with the i9 plugged in with the USB cable, drag the JAR or JAD files into the "RECEIVED" folder. After you're finished with everything you want to add, disconnect the i9. Touch your DOCUMENTS button, then "memory card," then "received," you will see your JAR/JAD files listed. Touch the file you want to install. The next screen, choose INSTALL. It will bring you back to the menu choices of "phone" or "memory card." Choose PHONE and select YES. It should give you a message when it has successfully installed. Then exit out to the main screen, touch the JAVA button. Select "Installed Java Software" and you should be able to use your newly installed JAVA apps and games.
