Nintendo DS Lite Console Logo
Posted on Dec 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have found l2 power chip loose in back of console does it need to be soldered back on thanks
Anonymous
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Apr 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
12251
Points
29
Yes,L2 or L4 on Nintendo DS Lite motherboard are power inductor,need to solder back,if dont know where to get,maybe following page can help you
http://www.wiisingonline.com/productsview.php?proid=3193&id=64&type=products
Anonymous
Level 2:
Guru:
  • Expert 110 Answers
  • Posted on Feb 07, 2010
Anonymous
Expert
Level 2:
Guru:
Answers
110
Questions
0
Helped
34104
Points
190
Yes you will need to solder it back on.
Regards,
SOD69
1helpful
Can i fix the L2 fuse in my DS lite with just a conductor pen or do i need the l2 piece and have to solder it
Hi, sorry I missed your comment on my previous answer, you need to actually replace the L2 inductor, simply bridging the solder joints will not work :(
tip
DS Lite not turning on? Read this tip to find out how to fix it!
Have you dropped your DS Lite and now it rattles?
Is it charging but not turning on?
Then this is the guide for you!!
A very common problem with the DS Lite is that when it is dropped a small chip called the L2 Inductor comes away from the motherboard. This will still enable the DS to charge but you will not be able to switch it on. This guide will take you through step by step how to repair your DS Lite.
Things you will need :-
If you are lucky then your L2 inductor is still rattling around inside your DS. If it is lost then they can be bought very cheaply off of ebay :- L2 Inductor Ebay (Please note - This is not my ebay username, just the person that I always get my parts from)
Ok now we have everything it is time to start. Clear a nice big area for you to work in.
First remove any game cartridges from their slots and the DS stylus, like so -
Next remove the battery cover and 2 small rubber bungs here -
Underneath the 2 rubber bungs are 2 phillips screws.
Next remove the battery and take out the circled 3 phillips screws. You do not need to remove the uncircled phillips screw in the battery compartment.
Next, remove the 4 circled tri-wing screws using the tri-wing screwdriver -
Ok, thats all the screws removed, now to lift the case off. Pulling up from the back with 2 fingers on the shoulder buttons gently pull up and towards you but only enough so that you can get the case tool in to help with leverage. See below pictures -
Work the case tool around the gap and the top cover should lift off easily. DO NOT FORCE IT! You will then be able to see the motherboard like so -
The L2 Inductor sits to the left of the motherboard, right underneath the power switch -
Make sure that when you took the case apart if the L2 inductor was rattling around, it has not been lost. Hopefully you have managed to find it. What you need to do now is resolder the L2 inductor back onto the motherboard. Hold the L2 Inductor in place and carefully apply the soldering iron to each end, like so (it does not matter which way round the L2 Inductor goes) -
If you need to hold the L2 Inductor use something like tweezers.
Once you have secured the L2 Inductor onto the motherboard apply a tiny amount of solder onto each end of the L2 Inductor just to give it a bit more strength.
Thats it! You are done! Congratulations, you have repaired your DS Lite!
Now all you have to do is put it back together and you are finished. There are a couple of important things you need to know when putting your DS Lite back together.
You must make sure both the power switch slider and the volume switch slider are in the right place. The power switch slider should spring back to where it is supposed to but these pictures will confirm where they need to be -
Volume switch all the way to the left
Power switch all the way to the right as you look at it
The case sliders also need to be in the right place too, if you do not get this right you will break the little tabs off of the switches!
Volume slider all the way to the left
Power slider all the way to the right
When you re-assemble your ds, start refitting the case from the front backwards. Get it all in line on the front and the back should drop down with ease. Again do not force anything!!
Replace all the screws in reverse order and you are 100% done!! Give yourself a pat on the back!!
Ds lite got dropped now not working it turns on but nothing on the screens ,,screens look ok help
You have most likely either dislodged the wifi module or the L2 component has come off the motherboard.
I would suggest sending it off if you have a warranty, take it to a repair shop if your warranty has expired or if you fancy repairing it yourself then you wil need to dismantle the DS lite.
If its the wifi module that has come loose then its just a matter of pushing it back into place. If its the L2 component it will need to be soldered back onto the board.
Hope this helps,
Regards,
SOD69
3helpful
2answers
Nintendo ds lite that shuts off unexpectedly
Hi again,
Ive been doing a bit of research and it seems that if the DS lite has had a knock the black coil near the power switch could have been knocked loose which would make the DS lite switch off randomly. If you want to see if thats the problem take the DS lite apart (for a dismantle guide click here) and check to see if its loose... its the black round thing with 100 written on it near the power switch. If its loose then heat up the solder round it and that should reset it.
If thats not it check the L2 transistor is firmly in place, again if its loose heat the solder and reset it.
Another thing you can check is the power switch make sure its solid and doesnt wobble internally i.e. the black moveable part only moves the way its supposed to, as well as checking the solder is solid.
Hope this helps, if it doesn't sort out your issue then get back to me and I will continue to help you.
Regards,
SOD69
I have a Nintendo DS Lite that periodically works. When it doesn't work, the screens are black but the green light is on. What could the problem be and why is it intermittent?
THe L2 fuse located directly below the power switch on the motherboard is loose and needs to be soldered back in to place correctly.
8helpful
Power is on but my nintendo ds lite stays blank (black screen) both screens
Did your DS get a small bang?
The problem you are having is the L2 fuse located immediately below the on/off switch when you open up the DS (lower screen).
If you give the DS a very mild rattle you will here it rattling around loose inside the DS (in most cases). A lot of the time this same fuse can be soldered back into place to fix the problem all you need is a soldering iron and a triwing screwdriver (eBay).
If it is this fuse and you cant find it, you should bring it back to Nintendo for repair or your local PC repair shop should be able to help.
5helpful
Nintendo ds won't turn on
Many times, it is the L2 Inductor chip that has popped off on impact- that's usually what you hear rattling around inside the housing...and it requires a TriWing screwdriver to open it. I tried re-soldering the L2 inductor back on the mainboard inside with a Hakko ESD protective soldering station, and it worked for a few days and then died again. The fix was finally desoldering another SMD inductor chip off an old PIII Socket 370 motherboard (with ChipQuik removal solder and flux kit) of very close to the same size class, from next to the Clock Generator Chip- figured it would be close to the right value, since I had no way to measure the micro- or millihenries value, and the voltage was around the value that the DS Lite runs on. The fix worked, and is still working, charging, and going strong. Usually the symptoms of the L2 inductor popping off, or failing, is being able to charge, but not being able to power up.
6helpful
3answers
Ds lite green light comes on but nt the screens
For me it was a loose Wireless board - pushed it back into place and boots fine.
2answers
Nds lite wont turn on
There maybe something wrong with the jack inside your Nintendo DS, you can easily get them repaired at a few shops, just tell them that the On/Off switch doesn't turn the DS on and they'll fix it for you, shouldn't cost an awful lot as they're just replacing something inside.
1helpful
4answers
HELP!...need to fix L2 black box to the motherboard in a Nintendo DS lite
My daughter's friend had the same problem. Soldering was difficult, but repaired the problem.
I used a very fine solder and 15W soldering gun, both from Radio Shack.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
