LG TRomm dryer. model dle2515s. check filter light wont shut off and setting indicator is continously flashing on multiple settings. I have check and cleaned the filter. not sure what else is going on
You might need to check the exhaust on the rear of the Dryer, or the blower motor iether one has lint inside, restricting the air flow
My LG GAS DRYER DLGX3471 would not run because the check filter, service man light, and the display said CL. I cleaned the area inside where the filter goes and the exhaust hose. no change, so i took the three screws on the back near the top off and lifted the lid. there is a service manual inside. i pushed all the connectors together in case one was loose. i ran it through the diagnostics menu and it checked out ok, and then the dryer ran. i dont know if cleaning the lint, pushing the connectors back together, or the diagnostic procedure was the solution, but now my dryer works and i saved myself the service call.
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
check filter light blinking
