Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
Hi my name is Mike Houston of DISH Network and I see youwant to program you're Akai TV to our DISH Network remote. There are some easysteps to allow setup to your TV and I will send the link, http://www.dishnetwork.com/SupportSection/remote-setup.Please select the receiver you have and it will take you to a help page. I willsend a link for a Power Scan and the power scan will find the remote code foryou; http://www.dishnetwork.com/SupportSection/power-scan-instructions.If you have any questions or concerns please e-mail me at [email protected].
Hello emanuelts! This Kimberly Escobar with DISH Network and I will be more than happy to assist you and provide you and help you with the information you need. You can follow this link http://www.dishnetwork.com/SupportSection/remote-setup here, you will find the codes to the different brands of televisions and the steps on how to program the remote. If you have any questions or need additional help please let me know You can reach me directly at kimberly,[email protected].
I'msorry I did also attempt to locate a Prima remote code within DISH Network's database aswell but unfortunately I was unsuccessful and have found no remote codesfor the TV you have. However, we can still attempt to program the DISH Networkremote to the Prima television without a remote code, this would be done bycompleting a Power scan. If you decide you would like to program the DISHNetwork remote to your TV using the power scan, I have included instructionsbelow to further assist you.
Withthe desired equipment on, press and hold the correct Mode button (In this casethe mode button will be "TV") until all the other mode button back lightsilluminate, then release.
1.Pressand release the Power button.
2.Pressthe Up button once a second while pointing the remote at the desired equipment.
Note: If the code for the equipment comes up, theequipment will power off.
3.Pressthe POUND (#) button. If the codeentered is valid for the remote, the mode light flashes three times.
After successfully completing the power scan to program the DISHNetwork remote to your T.V the remote should now control your TV. I hopethis helped! Please feel free to let me know if you have any other questions orneed additional help. -Kirstie DISHNetwork
Call Dish Network at 1-888-284-7116 and they can walk you through the remote program setup. Or you can look in the instruction manual for code searching using the DN remote control.
