Question about Samsung HL-R6167W 61" HDTV
Samsung DLP will not turn on
My DLP won't turn on. 3 lights on front blinking indicating the lamp is out but I have replaced it and it still won't turn on. Someone suggested it could be the ballast and I replaced it as well. Still 3 flashing lights come on. Don't think the color wheel is out because it is not making a grinding sound. When I turn the TV on it makes its normal beeping sound and I hear a click like the lamp is going to light up but it will not. It wil do this 3 times and just start flashing all 3 lights at me again. I have to unplug to get it to stop. HELP!!!!!
  • 8 more comments
  • Xenophon_1 Feb 01, 2008
    I've got the exact same problem. I used to unplug the TV to force a reboot--that used to work -- but not any more!
  • kim boman Feb 15, 2008
    I too am having the three-light problem.  It happened first within a month of buying it back in May 2004 and a service man was sent out. He replaced the bulb and said they had been having problems with this model.  It has continued to happen in waves but usually sorts itself out by repeatedly turning the power button on.  Today, after 5 hours of trying, the 3 lights are still blinking and unplugging it has not worked.  Even though I love the TV, I'm tired of having problems with something that was so expensive.
  • jm417 Jun 21, 2008
    I have the same problem described on the other posts. I have replaced the bulb recently and just replaced it again thinking that it my be the problem. Not so... If it is the color wheel, are there any tips on replacement, and cost?
  • Anonymous Aug 08, 2008
    I have had the same problem with our TV, we have replaced the lamp and the color wheel and still nothing! The lights are blinking indicating the lamp is out and when I try and turn the TV on the fans come on making a humming sound and after three attepmts the TV shuts down. This is a frustrating problem for such an expensive TV that is barely over 2 years old. Samsung has not been able to offer any help and seem to be ignorant about their product. I guess I will have to try a new ballast and if that doesn't work junk the TV!! I won't buy another Samsung after this!
  • theglueck Aug 19, 2008
    I came home and there was a loud humming in the TV I tried to turn it
    off and it would not. Now it will start for a second then the humming
    starts and then turns itself off. The lamp light blinks along with the
    red button that says "hot" I think. Does this sound like its the "color
    wheel" or something else, and is changing the color wheel hard and need
    of a teck or is this something your average Joe can fix?
  • wattsrostar Oct 01, 2008
    Same problem. My tv will turn on for a few minutes in working order, then shut itself down and the front three lights will blink continuously. Once this happens, I can't turn it off. The lamp, timer, and standby lights all blink. The lamp obviously still works because it will turn on - it just wont stay on. It did this for one day about a month ago and just began working on its own. I am quite frustrated because of the cost of the tv. My old, cheap tv's are all working great and here my new, expensive tv is ****!
  • kevinclark Oct 30, 2008
    same as above. wont start. Tries three times then shuts off
  • Anonymous Oct 30, 2008
    The ? is how do you tell if it's the Fan or the Color Wheel. THe spinning/grinding noise has gotten louder and louder on my DLP and now it starts up with a really loud grinding noise and the TV won't turn on. It was turning on before and the colors on the tv didn't seem right for a few minutes then everything would run normal. Now the TV just goes straight to that lound humming/grinding noise and then all 3 flashing lights go on. I'm pretty sure it's not the Ballast, the Lamp is only a few months old. So do you think it's the fan or the Color Wheel or something worse?
  • Anonymous Dec 25, 2008
    what do i do
  • Anonymous May 11, 2010
    did the cooling fan fix the previous problem
If your having the "3 light" problem it could be an indication of a bad lamp however if there is a buzzing or a grinding sound it could be one of two moving parts. The color wheel or the cooling fan. I would go the cheaper route and replace the color wheel first. The thing is the lamp will not turn on if there is a problem with one of the other two parts. TRUST me ... I've replaced all three parts just to find out it was only the cooling fan. (at least I have another lamp handy when the new one goes out). The motor on the cooling fan is too small for such a big fan so I would definately try it first. It's a big problem with the DLP tvs. Hope this helps.
Posted on Sep 27, 2008
  • 113 Answers
This is most likely your color wheel if it does not get up to the correct speed the set will shut down. You do not have to hear anything grind that is just the dead give away. Its about a 90 percent chance that this is your problem and would be the next place I go. If you order the color wheel make sure you get the correct one there are two for this set. You need to look if you have an L6 chassis or L3 this will let you know which one you need. If you call samsung they will need to know the lamp code on the left side.
Josh
Posted on Feb 08, 2008
Correction on the previous post ... change the cooling fan first. Not the color wheel. You'll save alot of money.
5 Suggested Answers
6ya staff
SOURCE:
Cary Leonardt
  • 304 Answers
SOURCE: Lamp Light still on after replacement
First, A common mistake made is when you insert the orange ribbon cable from the Color Wheel into the DMD bd. To correctly insert the Ribbon Cable you need to look at both sides. You will see a shiny silver side and a dull black/orange side. You must insert the shiny silver side AWAY from the Color Wheel or towards the rear of the set. Now for the Ballast. When you power up the tv,Do you hear a short Buzzing sound? If you do that means that the Ballast is trying to fire up the Lamp and is working. Next, do you hear the Color Wheel spin up? If you do not then you have installed the Color Wheel incorrectly and you need to repeat the installation while making sure that you hold the rubber gasket in perfect place or else it won,t work. Chances are the gasket is in the wrong position and is binding the Glass Wheel. The Ballast is on the right side of the engine and on top of the Lamp Housing. You will see two RED High Voltage wires coming out of one end. Don't worry, there is no stored voltage in the ballast so you won't get a shock providing you have unplugged the tv from the outlet. That is the first step before you change any parts any way. Listen for the correct start sequence. With the rear backing off and the Safety Interlock Switch is being held in the up position, turn on the set. First sound you hear is a clicking which is the power on relay engageing. Then you will hear the fans turn on and then the Color Wheel spin up. Once the Color Wheel spins up and comes to full RPM then the Exciter on the Ballast will Buzz for less than half a second and then the Lamp should light up. Now if you have installed the correct Lamp and correctly installed the Color Wheel and you either are holding up the Interlock Switch or have reinstalled the rear cover and tightened all of the screws you should have a working tv.
Posted on Jul 16, 2009
Axle80
Axle80
  • 73 Answers
SOURCE: hlp5063w 50'' DLP samsung
Sounds like you've already gotten into the repairs. The three major things that fail on DLP are the bulb, the ballast and the color wheel. If your bulb is new and you aren't getting anywhere, replace the ballast, if that is still a no go, then move on to the color wheel. If replacing those three doesn't fix the problem, you will have to whip out the multimeter and start looking for problems on the PSB. You can get a ballast on ebay for about $100. Start there. The color wheel should be very freely moving. If something is grinding and hindering the movement at all, you need to replace it. That grinding may not seem like much but it is likely enough to keep the wheel from spinning at proper speeds. The sensor then kicks in and tells the brain that there is a problem and the brain keeps the ballast from firing the lamp.
Good luck.
Posted on Mar 11, 2009
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: Samsung DLP HL-R5667W lamp won't fire. Changed
Was the replacement lamp the same part number as the original as there are different arc gaps for different lamps and the wrong arc gap will cause the lamp not to light. Since the ballast is powering up the lamp should light if the baalast is matched to the correct arc gap of the lamp being used.
Posted on Nov 27, 2009
axeist
Lou Grein
SOURCE: 52HM84 Toshiba DLP with apparent failed lamp (replaced ballast)
I found R3 on the original board to be open, along with reading an open on CR1, D5 and D6. All the other transistors and the transformer check out. The only thing I have to do now is find out the specs of the diodes. The replacement board also had CR1, D5 and D6 open (R3 was OK). There had been some threads on various locations where remanufactured boards had bad components (the transistors were changed but not some of the other components).
Posted on Jan 18, 2010
I have a Samsung 56" DLP tv. was watching and it went off. light on lower front blinks 3 times, when attempt to turn on. Could it be the lamp light?
Does these LED indicator lights that blinks?It is one of the LED light said lamp or bulb?The tv been used alots,and it at lest 2 years.U have not change the tv lamp or bulb to this tv?Change it,life of the lamp it over.
May 03, 2010 | Samsung HLP5067W Television
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Why does my samsung tv cut off by itself after 1-2 min and flash a red lamp button?
A little explanation first- this model (as do most Samsung DLP sets) will try 3 times to get the lamp lit before the microprocessor will give up and then the 3 lites on the front will blink indicating a LAMP failure. This process takes about 1 to 2 minutes. In order of probabilty, the failures are:
1) A faulty lamp and/or ballast. REPLACE LAMP AND/OR BALLAST
However, a faulty lamp and/or ballast are not the only things that will give this blink code-
2) If the color wheel has a bad bearing and turns too slow or not at all, the microprocessor WILL NOT let the lamp light, and then give a LAMP blink code. A bad color wheel will normally have some sort of abnormal sound- a low growl or high pitched whine is common. REPLACE COLOR WHEEL
3) ALSO, if the microprocessor (on the DMD board) in its color wheel rotation detection or processing fails, once again the lamp is prevented from coming on and you get a LAMP blink code. REPLACE DMD BOARD
IF THE SET EVER COMES ON WITH A PICTURE for even a fraction of a second or though it takes many tries, the lamp and ballast are good. The problem must be either the color wheel or DMD board.
Oct 26, 2009 | Samsung HLR5064W DLP Projection TV
Samsung DLP TV time, temp and lamp lights blinking... won't turn
Les,
I'm not a TV repair guy but my owners manual states that when all three LED's or lights on the front of the TV are flashing, that the lamp needs to be replaced. Might want to look into this. Good luck!
Greg
Aug 30, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung hl-r6178w 3 blinking lights
The power board ic converter is dead.
U can tries to go to the web buy the part and replace it yourself.Or hire the repair man part and labor $575
Aug 13, 2009 | Samsung HL-S5087W DLP TV
No picture on my samsung 61" dlp.
The color wheel if bad enough, will cause the lamp not to light. If the lamp is truly bad, you can't usually tell by just looking at it unless of course it is broken.
May 18, 2009 | Samsung 61" Slim-Depth DLP HDTV
Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Mar 26, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HL-R6167W 61" HDTV Logo
11,096 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
