Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
Posted on Dec 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a westell, model 327W and do not have the security code or the one we have does not work. Whar do we do?
Anonymous
Level 2:
Novelist:
  • Expert 94 Answers
  • Posted on Feb 08, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
94
Questions
0
Helped
45824
Points
188
Access the setup page through a web browser on a wired computer. In the address bar, type 192.168.1.1.
Default Username: admin
Default Password: password
If this doesn't work, try admin for the username and password. If still doesn't work, then you will need to reset the gateway. Take note that before resetting the gateway, you need to know the internet connection settings. Resetting the gateway will restore the settings to default.
Once you are in the setup page of the gateway, go to Configuration> Wireless> then look for the wireless security. It should show you the WEP key.
Enter the wep key on your laptop.
I hope this works! Good luck!
Erroe code 051099
This error indacates that there is a compatibility issue with the security settings of your router. WPA wireless security settings are not compatible with the Nintendo DSI. If your wireless network is set to WPA you will need to change the wireless security to WEP. If preferable you can also disable your wireless security all together. The Nintendo DIS is not compatible with the following routers.
  • Westell 2200
  • Westell 327W
I hope the information above has helped in some way.
How can I find my security code for my westell Versa Link 327W
reset the router and assign a new security code for the wireless security
I lost my cd for weestell versalink model
Hi!
You should be able to find most of the info you need from these sites:
Hope this helps!!
1helpful
2answers
Westell versalink 327w from bellsouth can't connect
Howdy,
I do not think this modem will work for you. Contact O.T.C. to be sure. For a few details...
I presume that you can access your Westell wireless modem/router 327w with the IP address of - 192.168.1.254. (Or you can simply type "launchmodem" in the address bar - (one word - no quotes)) This will definitely get you in. You will then see the setup menu. If you see the Bellsouth FastAccess Internet Service logo then you know you definitely have a Bellsouth modem.
Now, let's presume, you are using a Westell wireless modem/router 327w made for Bellsouth/ATT. If this is the case, as stated above, you will see the Bellsouth Logo on the setup page. Additionally, it is stated on the page below, that you cannot use a Bellsouth modem/router for any other ISP (Internet Service Provider) This is due to the Bellsouth/ATT firmware that Westell builds into this modem/router.
This is the page link:
http://www.dslreports.com/faq/bellsouth/3.141_Westell_327W__wireless__Info#13772
This is the relevant quote:
"The BellSouth supplied 327W (model C90-327W30-06) is made exclusively for BellSouth FastAccess. They are functionally different from retail Westells (or any model designed for use with other ISPs) and the firmware between them are not compatible and can not be interchanged."
That being said, you still might attempt to use this 327W with orlando telephone company but I do not know if it will work. (Doubtful...) I use the Bellsouth 327W and it is GREAT. (With Bsouth/ATT) Good luck.
P.S. - Please be advised that Westell does manufacture an identical 327W that does NOT have the Bellsouth/ATT firmware.installed. This is the "generic" version I suppose but I have no experience with this one. If you need more just ask. :)
Good luck,
J
1helpful
Set to work with centurytel instead of bell south
Howdy - You may have a two fold problem here. First of all the Westell wireless modem/router 327w has the access IP address of - 192.168.1.254. (Or you can simply type "launchmodem" in the address bar - (one word - no quotes)) This will definitely get you in. You will then see the setup menu. That problem solved...
Now, from what I understand, you are using a Westell wireless modem/router 327w made for Bellsouth/ATT. If this is the case, you will see the Bellsouth Logo on the setup page. Additionally, it is stated on the page below, that you cannot use a Bellsouth modem/router for any other ISP (Internet Service Provider) This is due to the Bellsouth/ATT firmware that Westell builds into this modem/router.
That being said, you still might attempt to use this 327W with centurytel but I do not know if it will work. I use the Bellsouth 327W and it is GREAT. Good luck.
My brother just gave me a Westell versa-link model 327w router. there isn't any instruction/opeartor's manual with it. is there a web site with instructions on how to go about hooking this up? Thanx Wayne
The 327w router is distributed by Verizon, an internet service provider. On their website you find tons of info on this model.
Go to the Verizon support page and enter
<westell versalink 327w> in the search field.
Furthermore here some interesting info for you:
Westell versalink 327w Quick Start Guide (700k)
Westell versalink 327w User Manual (10M)
Cheers
Critter
2answers
Westell 327W & Verizon DSL
I have centrytel DSL and westell Model 327W
1helpful
Westell model 327w
you can run another ethernet cable from your westell modem to your laptop. hence, if you want your laptop to connect wirelessly, it must have a wireless card/adapter inside. if it already has a wireless adapter, it should automatically detect your wireless network and you just need to connect to it (note: you need to enter the correct wireless security/network key if you have enabled it on your modem). by default the serial number is the ssid of the router and the wireless security is disabled. but if you are not sure of your wireless security, log on to the modem's web user interface by typing http://192.168.1.1 on your web browser's address. then go to the wireless section and verify your wireless settings from there.
hope this'll help you.
ciao!
1helpful
3answers
Westell 327w
xbox live connection test MTU failed
Top Westell Wirespeed Computers & Internet Experts
Sean Wright
Sean Wright
deton8 von Splosion
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
