Question about Xerox 212 Laser Printer
Error codes on xerox 212
We keep getting error code E5 coming on the display on our photocopier. Any ideas what it means as we have lost the manual
  • gabirlux Feb 17, 2009
    how make password on the Xerox 212 ?
  • 239 Answers
A E-5 is a problem with the registration sensor.
Check the side door and see if the metal springs are out of postion and bent. If they shorted in anyway, it might of taken out any of the components in its path.
They need to contact good on the side card they contact with.
The end result is, either the side door has to be replaced, or any of the circuit boards in this path has to be replaced. they are all difficult to get to.
Call Xerox for repairs, or if they do not service the machine, try buying a new copier.
Posted on Oct 17, 2009
    President:
  • 2,072 Answers
An E5 most frequently comes from the door connector . When you open the right side on the upper left there is a black connector. Those contacts may be dirty or bent. Carefully clean and reform if necessary. I will send you some other info to follow.
Also if you take the copy cartridge out and and clean all the contacts inside the machine you can see, it may also correct it.
Recurring problem with E5. Door connector has been replaced, contacts on Interconnect board are clean and shiny, but interlock connection still not reliable. When you remove the rear motor cover and press on the door connector, the E5 goes away and the fuser starts to warm up. The door connector is mounted loosely to the door to allow it to locate itself with the interconnect board when the door is closed. If it is too loose, the connector will not make good enough contact to complete the interlock circuit
Posted on Jan 25, 2008
  • 1 more comment
  • Rick Kasper Jan 25, 2008
    Add a small block (about 3/4" x 3/4" x 1/2") of foam under the connector on the inboard side to limit how much the connector rocks backwards. There is a vertical post of plastic in the door assembly under the connector which will hold the foam in place. This provides enough extra pressure to make a good electrical connection when the door is closed
    Problem:
    E5 code after rap has been followed.
    Cause:
    HVPSU faulty.
    Resistor burnt out near to main PWB connection.
    Solution:
    Fixed! Did not fix.
    Replace HVPSU
    E5: The Door Transport is open.
SOURCE:
How can fix error u4 code in xerox photocopier machine
http://xeroxmachineerrorcode.blogspot.com/2016/07/u4-error-code-xerox-wc50165020.html
Unsure what model Xerox is displaying error u4.
To pursue your question further, please provide Model name and number that is on the equipment in question.
My Xerox Workcentre 5020 machine showing U4 error How can solve this...
Feb 19, 2018 | Xerox Office Equipment & Supplies
What does an E5 code mean?
Make and model helps, but here are all the E5 Error Codes we get asked.
On a cellphone?
E5 code Google Search
On a washing machine
e5 error code code washing machines Google Search
Dishwasher
e5 error code code dishwasher Google Search
Stove / Cooker
e5 error code code stoves Google Search
Fridge
samsung fridge e5 error code Google Search
Aug 27, 2017 | Cell Phones
What is the error code E5 on bluestar air conditioners mean
Problem
Overheat of inverter compressor motor
Cause
Shortage of refrigerant amount Leakage of four way valve
Defect of connector contact
Aug 14, 2014 | Heating & Cooling
Xerox 560 error code 127-212
Error Codes
If an error caused the printing to end abnormally or a malfunction occurred in the printer, then an error message code (***-***) is displayed.
If an error code not described in the following tables is displayed, or the problem persists even after you have tried the following solutions, contact the Customer Support Center.
Tip
If an error code is displayed, all print data of the printer as well as print data stored in the built-in memory of the machine is discarded.
Error Code: 127-212
Error Category: Print; Other Problems
Cause: Detected an internal print check error by the FreeFlow
Print Services Controller.
Remedy: Remove and reinsert the command/video cable between the FreeFlow Print Services Controller and the printer. Power off and on both the printer and the FreeFlow Print Services Controller. If the problem persists, call the Customer Support Center.
*** extracted from my Fuji Xerox Color 560 Printer - Printing Systems User Guide
*** I assume we have the same printer
Jul 13, 2012 | Lenovo ThickCentre M58p Desktop 7479A3U
My canon photocopy machine displays an error code presenting as (E 000602 - 0003)Please help me solve this problem.
Hi these means that you have HDD trouble, and it needs to be changed and upload the system on it - CALL SERVICE.
Aug 19, 2010 | Canon Office Equipment & Supplies
Xerox 5750 error code 005
this error comes from fuser unit u have to change fuser unit
Aug 19, 2009 | Xerox DocuColor 5750 Printer
Xerox c2424 error code
the error code is "printhead stuck in the tilted position or not tilting properly over the CAM, due to problems with the process motor gearbox" the 6375 is your print count, are you under warranty still by xerox?
-Carl, please let me know if this helps.
Jun 20, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox 212 copier
It melted in the fuser and has over heated.
You will need to replace the fuser. Google a business called The parts drop, call and ask for Britt.
Dec 22, 2008 | Xerox 212 Laser Printer
J8 Error Code
There are a few different part numbers for those cartridges, the chip on them bills differently.
A J8 means although you have a 212 cartridge, it has a chip on it that does not match your machine setup.
A J8 indicates a mismatch in the cartridges and the machine. No you do not have the wrong physical cartridge, it just has a different chip on it.
Nov 08, 2008 | Xerox 212 Laser Printer
Xerox 212 Laser Printer Logo
392 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
quennie732
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
