New Bright Holiday Express Santa's Mailbox Car Logo
Anonymous Posted on Dec 22, 2009
Music will play but train will not move or do any other function
We put it together and the train does not move on the tracks. There were no instructions, so not sure if there is another switch.
Thanks
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 28, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
460
Points
I'm not spending money for asking if there is a button to push to make the train go around the track! That is a simple "yes" or "no" answer! I can promise you that I will not buy another product from your company and will tell all my friends about my experience with your product!
Spaldingsr
I have a New Bright 384 Christmas train set. I purchased other tracks (384) and rail cars. How many tracks and cars can I safely add to the original train?
FIRST and MOST IMPORTANT I'm not a professional train builder .. but i am an old kid a heart and i've had electric trains at Christmas all my life. as far as track is concerned it shouldn't make any difference how much track you have... the electricity remains constant in the tracks and is only expended at the point where the train contacts it .. a poor connected track can cause a slow down or stoppage so if it happens again check individual track pieces for a poor connection, dirt, corrosion, loose connections where the tracks slide together .. it's probably a loose track connector that happens a LOT you can run a jump wire across a loose track connection (if you know how) .. don't use pliers to crimp them that only makes it worse .. i've made that mistake. you can get into trouble by adding too many additional powered items like another train or another electric station beyond what it came with.. when you do that you can stress the transformer.. in which case buy another transformer for all your stations and only use your original stuff with the old transformer... but yeah have fun with it string as much track as you want.. Merry Christmas
Dec 15, 2022 • The Toys
1helpful
I need instructions for putting the train and track together
hi Joyce.
is this a electric train set or a battery set?
could you please give me more info on this please.
can you please tell me what train set this is.
or go to this link might help you out on how to put a train set together.
how to put train track together Google Search
Dec 01, 2017 • The Toys
The train keeps jumping off the track
Is the track properly and carefully put together? Is one or more sections damaged take one of the cars and gently push it around watching in those places where the train derails. If it only happens at a track joint look at it more carefully.
3helpful
Lego train 7938 will not move. not sure about remote control functions
My Lego passenger train 7938 has been put together but the wheels will not move I have triple checked all the connections
The web site that was supposed to be the problem resolving site is down
1helpful
I have a rio grande train set and I can not figure out to put the tracks together?
HOLD TWO PIECES OF TRACK TOGETHER SNAP ONE SIDE TOGETHER THEN SNAP OTHER SIDE.
5helpful
3answers
Peg Perego Thomas Train Track Rider
Hi
Have you tried keep pressing the right hand button down. When you press the button down and hold the press, then the sounds are finished, the trains starts driving. When you release the button the train stops at once.
9helpful
9answers
I cannot promise that this is the problem, but this is where mine was broken, and you may be able to fix yours this way.
I was able to remove the plastic around the tender and access the motor. Using alligator clips, I was able to connect the battery directly to the motor, bypassing the circuit board. The motor functioned, therefore the only component that seemed to be defective was the circuit board, located behind the speaker in the engine unit.
As far as I know, the only place to buy a replacement circuit board is from www.tigerimports.com. Search for part number MEVA0024. Cost is around $15 + shipping (around $6 or so).
I should be receiving this part by the end of the week and will report if it fixed the problem.
Thanks for using Fixya. If I didn't help your situation, please DO NOT label this advise as "inappropriate".
Mar 12, 2009 • Toys
2helpful
The red button on the right must be held down for anything to move. It turns the lights on, makes some train noises, then moves forward. If you don't hold the button down, nothing will happen. Note that when the train is underway, the left red button becomes a train whistle. Otherwise, when the train is not running, that left button produces music. Hope this helps.
Top New Bright Toys Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Don A
Don A
Are you a New Bright Toy Expert? Answer questions, earn points and help others
