Nokia 6300 Cellular Phone Logo
Anonymous Posted on Jan 11, 2018
Hi my phone is staying lit up that is i have the screensaver sleep mode and power saver on as i usually do and suddenly none of these are working. the phone just remains lighting. i tried adjusting the screensaver saver and turning it off and checking it again but nothing has worked so far..suggestions?
I have a dell studio 540 desktop, I need to restore to factory settings but my monitor will not stay open. It opens for a few seconds then immediately goes into power saver mode and turns off, how can
I see two things here, but need clarification;
1) Monitor goes to Power Saver Mode, then turns -> OFF?
Sure that monitor didn't go into Standby Mode?
2) Why are you performing a restore back to factory settings?
Pick up a virus?
Primer;
The monitor receives a signal. A video signal. The video signal comes from the computer.
If the monitor is NOT receiving a video signal, then the monitor will state No Signal.
This is for older monitors.
New monitors do not state No Signal anymore.
It's Power Saver Mode, or Sleep Mode.
If the monitor is truly OFF, the Power On button will Not be lit up.
Or the Power On LED light on the monitor.
Monitor power on LED is lit, or Power On button is lit?
Monitor is not receiving a video signal;
Use a monitor cable from a KNOWN to be working monitor, for a temporary test.
OR,
Use a Known to be working monitor, and it's monitor cable.
Need to find out if monitor cable is good.
Monitor cable checks out good?
Then problem is computer.
The two leading issues with desktop computer failure, is;
1) Computer is dirty inside
2) Power Supply inside computer is bad.
Please post back in a Comment.
Regards,
joecoolvette
I am unable to access the internet from sleep mode Can only get on internet from shut down mode
Three possible causes of sleep mode. first, an extensive screensaver with password lock prevents display. A condition that is observable as a blankscreen also known as sleep mode. Second, a computer power saver settings that shutsdown during idleness. Third, An improper shut down of the computer would have caused a sleep mode to save the system data files.
Restoring the computer to regular functionalioty
First solving predictable sleep mode settings
1. A movement of mouse pointer across the screen should reestablish unprotected password modes
a. password protected sleep mode would display an promp message requiring key code soon after the mouse pointer has changed direction
sloving unpredictable sleep mode settings
1.A computer power saver, screen saver, or splash screen displays prevnting programs acess would require manually powering off the computer system.
a. A manual power back on of the system should restore to program functionality mode
important notes
1. contact expert technical assistance
2helpful
Dell 4700 sleep on bootup
ok here's what i can suggest. Two things.
1. Check your power settings by going to the Control Panel and then going to Power Options. Take a look at the power schemes..specifically the option where it says turn of monitor...you can select the "Always On" power scheme....if this doesn't do it...
2. Right click on your desktop and click on Properties. Go to the Screen Savers and verify that the time before the screensaver comes on is not something ridiculous like 1 minute. You can just disable the screensaver if you'd like by selecting "none"..
I'm pretty sure you're dealing with one of those two problems.
SP2208wfp monitor goes into sleep during videos
Assuming you are using Win-XP, go into control panel, Appearance and Themes and Choose a screensaver. There should be an option below the screensaver choice to adjust Power Saver settings.
Monitor is constantly switching into digital power
Is your screen saver kicking on every 1 min.?
On desktop... RIGHT click, choose Properties. Screensaver TAB.
You have screensaver and POWER (sleep options) you can choose.
Monitor goes to sleep mode quickly without video cable
right click on desktop - click properties - click screensaver tab, and dropdown menu to none. this turns off screen saver. For power/hybernate....
start - control panel - power options. Change all pull down menus to "never"
Problem solved.
Dell XPS420 Freezes after being in sleep mode
Is there a reason why you cant turn off sleep mode and just let the screen saver kick in? You can do this by right clicking on your desktop and goto properties. Then ScreenSaver, then click on power.
Change these values to never and then go back and set your screen saver...
Hope this Helps...
Joe
DataMiner
ENERGY SAver is stuck on
I know it's an older post, but you still may be waiting an answer:
What is probably happening is Your power board is failing to maintain power enough to run the bulbs and the rest.
That is why it takes long to start up and why it goes into sleep mode.
Does the power button stay lit (getting signal) or turn to amber (sleep mode) or does it flash.
powerseller
bammbammfran
5helpful
Nokia n72 screensaver activation.
You need activate it under
Themes->Power saver->(Select a theme)
You can preview it under
Themes->Power saver->(theme)->Options->Preview
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
