LG LRMM1430 Microwave Oven Logo
Posted on Dec 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The bulb has gone on my microwave. How do I change
The bulb has gone inside my microwave, how do I change it and where do I buy a replacement? It is a Samsung m 959.
Thanks
Anonymous
Level 2:
New Friend:
  • Expert 108 Answers
  • Posted on Dec 22, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
108
Questions
0
Helped
20355
Points
205
Take the screws out of the cover take it off can now access the light-check appliance store or hardware for the bulb.
Change bulb inside ge pvm1870Sm2SS
You can download GE owner's manuals and installation instructions
here.
The manual will cover bulb replacement.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
How to change inside bulb
Normal procedure is to remove case cover to access the bulb.
Usually several screws on the back and some partially hidden on the front to remove. Sometimes the screws require a Torx screwdriver.
Unplug unit and avoid touching any wires.
Replace bulb with exact type.
1helpful
Need to change the Cooktop light on a GE JVM1441. The directions say "After breaking the seal, remove the bulb by gently turning." To what seal are they referring and where do I find it. All I see is a...
Just gone through it myself. Wife was trying to change the bulbs and broke them both leaving the screw part stuck inside. I took the whole bottom panel off. It is 5 screws and comes completely off the microwave. Makes things much easier access
LIGHT INSIDE OF OVEN NEEDS REPLACING --HOW DO I GET TO BULB
normally there is a side door that can be removed to replace the inside light bulb, the microwave bublb is changed from a different location normally on the back.
WHERE IS THE LITE BLB COMPARTMENT
You should be able to see the bulb, if not, then you have to unsrew the top and change the bulb by unswrewing it, then just buy a new one and put it on.
Replace Microwave Light
Apparently there's a flaw in the design. My light has gone out/ been changed roughly evry 9 months. No longer under warranty and cost to have someone come in and replace is outrageous. Light bulb is located on top of the oven. You need to remove the top to get at it. Looked fairly easy.
1helpful
Kenmore Microwave 721.66319 500 Light buld gone out - now what?
First of all, since this will involve disassembly, we have *critical* safety & disassembly info at our site in our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams for your Kenmore model here: http://www.searspartsdirect.com
Enter your model number as 721.66319500.
The light bulb is shown in the "LATCH BOARD PARTS" diagram and it's located in the area of the door switches.
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
It's best not to touch the bulb with bare skin, as the oils can shorten thee bulb's life. And I recommend a high quality bulb from places like Home Depot, instead of cheap types from the grocery store.
We're happy to help and we appreciate your thoughtful rating of our answer.
Sharp Microwave R-206 800W
open the housing, look where the bulb is located, unscrew the holder of the bulb and if the b.ulb is screwed at the holder, replace it. if the bulb is attached to the holder then replace the whole bulb assembly. i hope i was able to answer your problem
Top LG Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
