Can't find comcast remote code to control tv
SOURCE: SYLVANIA SRCD227 REMOTE CODE
First tell me what brand tv and date of mfg & model# maybe I can help. Chuck [email protected]
SOURCE: Comcast remote control won't turn on or off Sylvania LC321SS9 TV
Usually you need to make the remote search for the right code that will work with your TV. Google you Comcast remote model for instructions and it willl how you the right steps.
SOURCE: Comcast remote won't accept codes for Proscan TV
I had the same problem. I have the 40 inch Proscan and they supplied a remote control guide for comcast. It was only 4 digits and it did not work. I called Comcast and they did not know. I found it needed 5 digits so I added a 1 and it worked The code is 10178. Hope it works for you.
SOURCE: Comcast remote code for sylvania lc427ssx
I had the same problem, I ended up buying an RCA Universal remote, when I had no luck with the codes I tried the autoscan feature, to my surprise it worked perfectly.
SOURCE: Comcast universal remote control does not have setup code
Try 1864. It worked on my Media-Com remote when none of the other codes worked
