Labtec 961307-0914 Webcam Logo
Posted on Dec 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to install Labtec drivers for my labtec webcam for Windows 7. It worked perfectly fine with Windows XP and Windows Vista. I updated to 7 and nothing.
micky dee
Level 3:
  • Master 3,015 Answers
  • Posted on Dec 22, 2009
micky dee
Master
Level 3:
Answers
3015
Questions
0
Helped
1061321
Points
8762
You can contact Labtech from here
http://www.labtec.com/index.cfm/service/splash/AMR/EN,CRID=3
You may have to run it in Compatibility mode if Windows 7 webcam software is not available - I'm sure they can advise you
To navigate to CM on my logitech I rightclick the webcam shortcut icon on the desktop and click 'Properties' and then the 'Compatibility' tab.
Please driwers for windows 7
on this page you can download drivers for Win XP and Vista.
http://www.labtec.com/index.cfm/service/listing/EUR/FR,crid=68,crid2=1764
Try the driver for vista, they could work with windows 7
Driver for my labtec notebook webcan runing with windows 7 entreprise 32
Well you may please follow the link below -
http://www.labtec.com/index.cfm/service/listing/EUR/EN,crid=68,crid2=1764
(you can download the vista driver from the above link and then try to install it on window 7, many times it worked)
there is no specific driver for window 7
Good Luck!!
Thanks for using FixYa!!
I need to update my labtec webcam/mic driver to work with windows 7 can this be done
First check the labtec website to see if they have a Windows 7 driver for it.
If not, it might be that Windows 7 supports the webcam directly, but I guess you have tried that.
Last option is to look for a compatible webcam driver for Windows 7 which is not from Labtec. This is possible since Labtec uses third party webcam components. Try using a driver finder application for that.
48helpful
Driver windows 7 for labtec webcam
Download the nearest driver to your operating system from the url above, if you are using 64bit use vista 64bit and same as 32bit
When you first install the driver it will give you an error message, "you cannot use the current version, dont worry the setup files get extracted to a directory:
C:\Program Files (x86)\Labtec\WebCamWebInstall\Drivers\x64 or similar.
Open device manager by entering the properties of my computer find the webcam in the list it should have an exclamation mark on it, right click on it and update driver, locate the driver from a file directory as above, it has 2 sub directories, you driver is in WIM64 or 32 depending on what your system is, and press ok, it should find the driver and install it for you.
I hope this helps and let me know how you get on.
7helpful
3answers
Can't get it to work on windows 7... any workarounds ?
want driver for my labtec webcam 5.1.0 for window 7 ( anthony )
Problemtoinstall with Windows 7
I could not find the Windows 7 64-bit drivers on Labtec website. However, I would suggest to download & install the Windows Vista 64-bit drivers.
Here's how to download them:
1. Go to: http://www.labtec.com/index.cfm/service/listing/EUR/EN,crid=68,crid2=1764
2. Scroll to the bottom of the page to the section "Software for Labtec Notebook WebCam, Webcam Pro, WebCam Plus, plus SE and labtec® webcam".
3. From the "- Select Your Operating System -" drop-down menu, select "Windows Vista 64-bit".
4. From the "- Select Your Language -" drop-down menu, select "English".
5. Click on the "download" button to start the download.
1helpful
Updated to windows 7. labtec web cam not
HI,
There are currently no windows 7 drivers/softwares available for windows 7 from Labtec.
The only solution is to contact the Labtec support team and ask them to email you the windows 7 compatible software for your camera.
Contact Details:
44-203-024-81-61
Thank You for using fixya.
1helpful
2answers
Webcam problem /windows vista
WRONG .... i wish people did research before thinking they know everything ....... and its not Vista more of Labtec, with certain old usb labtec cams, they decided to stop all support on them, there fore the latest drivers from labtec for vista may mean it wont work. There are ways around it but u need to be lucky and find drivers which are version 6 or below first for it to work.
Top Labtec Computers & Internet Experts
Rob Hill
Rob Hill
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Labtec Computer and Internet Expert? Answer questions, earn points and help others
