Question about MTX Dodge Ram Quad Cab 2002-2003 Thunderform, Loaded with Dual 10 Inch Subs and Amplified, Charcoal Car Speaker
03 Dodge Ram 1500 cold air on driver side, warm air on passenger
I get cold air from the driver side vents and luke warm air from the passenger side vents when I try to heat my 2003 Ram 1500. I've read almost all of the 315 posts to this site about blend doors. I've taken the dash out, down to the point where I can somewhat check all four actuator motors and flapper/blender doors. The only motor I didn't physically remove was the one that you have to cut out the metal framework, but I could see movement of the small doors that open the air to the foot/floor warming vent by using a flashlight and looking into the vents near the floor of the center console. Examining the four actuators and doors as best that I could, here are the results (the four actuator motors are labeled with a white sticker on the wire leading to them):
Actuator Recirculation Motor (on the far right of the unit) - Moves the large recirculation door that I can see and feel by removing the recirculation fan on the passenger side.- mine operates properly by changing from a Max setting to any standard setting for the area desired to be heated or cooled (switch on the far right of the three climate control switches) I can actually view the door moving and it is intact.
Actuator Driver (second actuator motor from right side that operates two doors in unison) - Motor operates properly when selecting the middle climate control switch to either hotter or colder. The actuator rotates properly with switch movement. I disconnected the metal connector that operates the two flapper/blender doors in unison, and both doors appear to feel normal but I cannot visually see them.
Actuator Mode 1 - I was able to remove the actuator motor and it rotated properly when the correct console switch was moved (can't remember which one). By moving it with my hand, I was able to turn the white mechanism that the switch controls, and feel that the door seemed normal and that the limit stops were working properly. I could also determine, that by manually moving the door while the blower was on, the air would change direction to the correct area.
Actuator Mode 2 - I cannot access the motor to remove it since it is behind the metal framework that the repair video says would need to be cut out, but by looking into the floor area vents with a flashlight, both doors seem to move properly when going from floor selections to defrost selections on the middle console switch.
Both of the hoses to the heater core feel warm when I checked them from the engine compartment at the point they enter the firewall. There is also a proper level of radiator coolant/antifreeze and the Air Conditioning cools just fine on a hot day.
I still cannot determine why I would be getting warm air from the passenger side and cold air from the driver's side. Please help.
  • 2 more comments
  • jetbridge Jan 14, 2010
    I had to take out the dashboard to remove the entire heater "box". This showed all four actuator doors and motors to be working fine. At this point, I took it to a mechanic and discussed it with him. We agreed that the only thing left in a heating system would be the heater core which is also inside the box. The part was $125 and the mechanic charged 2.5 hrs labor to drain coolant, replace core and reinstall the dashboard and trim. ( the book called for 4.9 hrs to replace the heater core but since I had most of it removed, he was able to cut the price since most of this was labor intensive.) $360 out the door. Works perfectly. I think the heater core was partially blocked and was only circulating across half the core, therefore giving lukewarm air and only on one side due to the design of the doors and core location. Good luck.
  • robdean
    robdean Oct 17, 2012
    I have the same trouble, Ive done the exact same thing you have. Check all doors,seem fine, I have flushe out the core before, makes no diff still cold on driverside. I have the dash apart now and dont know what else to do??? Help NEEDED!
  • Kyle Remi Aug 24, 2013
    i had the same problem and lou and behold the r134a was only sittng at 16 psi, topped off and working great. thanks for the help!! =)
    New Friend:
Mine was cold on dr. side and warm on pass. side during summer and reverse in winter,turns out it was just a little low on freon.put a shot in and it works great now.
Posted on Jun 23, 2010
    New Friend:
I had the same problem took the dash off and everything was working. I read one of the responses and went to Autom store and got a can of freon with the gauge on the tube $26.00. came home it read low and I filled it. Started working immediatly.
Posted on Jul 10, 2010
    New Friend:
Did you ever find out what your problem was i am have the same problem if you got it fix please help and how much it cost
Posted on Jan 13, 2010
    Sergeant:
    Champion:
  • 382 Answers
Try going to a good rad shop they can probabl;y help you out with most heater problems call one first to see if they can answer your [problem they will tell you if they can or can't
Posted on Dec 23, 2009
  • red echo 02 Jun 24, 2010
    a lot of the heater problems can sometimes be in the rad or heater core a good rad shop can usually apply pressure to the heating system and clear it up.Call one and explain the problem. They will tell you if they can help you or not
SOURCE:
I have a 2003 Tahoe and when I put the heater on only the driver side get warm passenger side blow cold air
2004 Chevy Tahoe. Hot air out of vents on driver's side, cool ...
answers.edmunds.com > Edmunds Answers
Jun 25, 2009 - Hot air from vents-driver side and cool air from vents on passenger side. ... The driver's side vents were blowing out hot air, and everything else wasblowing cold. ... you'll literally have to restart your tahoe/yukon at every traffic light to keep cold air coming ... I was also getting air only out of the defrost vents.
Hot air out front drivers side vents 05 escalade - YouTube
? 3:14
https://www.youtube.com/watch?v=5lnd8UNcx6M
Aug 3, 2013 - Uploaded by South FL Mud Club
Suddenly hot air started blowing out the air vents only on the drivers... ... is a very helpful video ,I wondering if this part number apply for my 04 chevy tahoe? .... I have cold air out of thepassenger side, but warmer air out of the driver's side. .... 2003 Tahoe No Rear Heat Fix, Suburban, Yukon XL Repair!
Heating and AC Temperature and Air Delivery Mode Door ...
repairpal.com > Problems > Chevrolet > Tahoe
Driver/passenger air vents blow hot then cold when using A/C. Back to cold when you restart the vehicle. Upvote (35) ... 2003 Chevrolet Tahoe ... I have a 02 Tahoe ,and the heat system is working only on the ceiling side of the car when turn.
2004 Chevrolet Tahoe Blows Hot Air - Sparky's Answers
Jan 21, 2016 | Cars & Trucks
I have a 2008 Toyota Corolla and heat on the left side and the right side is cold, what to do?
Heat is blowing on passenger side, but cold air ... - RepairPal
repairpal.com > Questions > Dodge > Ram 1500 > 2002 Dodge Ram 1500
Dec 7, 2009 - When I turn on the heat, the passenger side is receiving warm/hot air but ... blow hot air on the drivers side and it would get cold right away. about a week ago... I have a 2008 Dodge Ram 2500 SLT. ... Regardless of the settings cold air blows from the left vent and on the floor on driver and passenger sides.
Temperature Blend/Recirculation Doors May Fail and ...
repairpal.com > Problems > Jeep > Grand Cherokee
2008 Jeep Grand Cherokee143,000Visitor. I get cold air on driver side and warm air on the passenger side. Upvote (29) ... right side air is always at the coldest. no heat on the right side and air temp will not change, left side works good. .... Models: · Honda Accord; ·; Toyota Camry; ·; Honda Civic; ·; Acura TL; ·; Toyota Corolla ...
Jan 16, 2016 | Toyota Cars & Trucks
2003 dodge ram 4.7 heat/air trouble
if you have a tilt wheel,you may have a broken wire,replace the whole colunmb also,,,,,,,,,,,,,(pics)look for 2 and 7 ,,blend door actuators,,
May 07, 2015 | 2003 Dodge Ram Pickup 1500
On a 2003 ram 2500 I'm not getting heat and after
check your anti freeze... should have bought a chevy.
Feb 10, 2013 | Cars & Trucks
My heater does not blow in floor in a dodgeram 1500
the heater vacuum motor and lines needs to be checked.Also get the blend door checked.
NO HEAT ON FLOOR VENTS
As per your problem mentioned. There are few solved help links to troubleshoot these problems. Go through the list and Click the link below:----
2000 Toyota Avalon: No heat on Passenger Side?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
No heat on Oldsmobile Silhouette?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
Hot air on the driver's side vents only?
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
Temperature gauge does not move and no heat when heater is ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold?
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold?
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
Ford F150 Ac only blows through defrost vents?
http://technoanswers.blogspot.com/2012/01/forf-f150-ac-only-blows-through-defrost.html
Dodge A/C come out of defrost vents only?
http://technoanswers.blogspot.com/2012/01/dodge-ac-come-out-of-defrost-vents-only.html
Ac vacuum line on dodge cummins?
http://technoanswers.blogspot.com/2012/01/ac-vacuum-line-on-dodge-cummins.html
Ford ranger AC blows cold through defrost vents instead on cabin vents?
http://technoanswers.blogspot.com/2012/01/ford-ranger-ac-blows-cold-through.html
2005 Chrysler PT Cruiser: A/C Blows Warm?
http://whoisbyme.blogspot.in/2012/06/2005-chrysler-p8t-cruiser-ac-blows-warm.html
2009 Mercury Grand Marquis: A/C blows Cold From Defrost Vent Only?
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
AC not blowing through Vents on 2007 Chevy Trailblazer?
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
Passenger side temperature is warm air out of dash vents?
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
Heater in 2003 Dodge Ram 1500 blow cold air out of vents on driver side and warm air on passenger side when turned to heat.What could be possible cause?
Not sure about your dodge, but on hondas there is a lever under the driver side vent to allow fresh(outside air) when its cold out, it will be cold, even with the heat on inside, so check to see if your has that lever somewhere on that side...hope that helps
Jan 02, 2011 | 2003 Dodge Ram Maxi
The heater in my 2003 Dodge Ram 4x4 will not heat up or gets only luke warm & only on the passenger side....any suggestions?
Cold on drivers side and heat on passengers side, actuators working properly and blend doors are moving. Heatertreater is for piece of plastic on actuator motor. I moved blend door by hand after disconnecting actuator and works fine, both sides freezing when moved in opposite direction.
Dec 04, 2009 | 2004 Dodge Ram 1500
Driver's side air blowing warm, won't change
Sounds like there is a crack in the vent that leads to the drivers side, and hot air from the engine is leaking through.
Aug 29, 2009 | 2003 Hummer H2
2004 Ram 1500, AC Blows cold on drivers side, but warm on passenger side? Not sure what it could be, and if this part would be covered under the 70/70000 warranty, which i doubt since it is not a...
I would try other settings like heat and regular air to see if air is going to this vent. If it does, the flap may be stuck inside that directs the cold air when it is turned on. The vent is moved by a vacuum actuator.
If you have air on one side, that is a good sign. It may be low pressure, but if the air is cold, it is likely the vent stuck shut.
Jun 23, 2009 | 2004 Dodge Ram 1500
MTX Dodge Ram Quad Cab 2002-2003 Thunderform, Loaded with Dual 10 Inch Subs and Amplified, Charcoal Car Speaker Logo
4,688 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Mike Duncan
Mike Duncan
Philip Armitage
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
