Apple iPod touch Logo
Posted on Dec 22, 2009
IPod Touch does not connect to my home network?
Any idea why iPod Touch does not connect to my home wireless network? It recognizes my wireless network, I enter my password and still unable to connect. Any manual process or bypass I should try?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 24, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
314
Points
In my case, I keep getting endlessly prompted to enter my passcode for my wireless router. I found that if I reboot the iTouch - hold down the top power button and slide the "slide to power off". Wait for it to finish powering off and then power it back on by holding the same button. When it comes back up it automatically connects to my home network again. Seems to happen every time I connect to an outside wifi network and then return home... I wish I knew WHY it does this - I suspect it has something to do with how my home wireless router is configured.
1helpful
How can i update my iPod model # MC086LL
The iPod touch is not only a music player, but also your gateway to the world via the Internet. In order to connect to the iTunes music store and use the email and web-browsing features of your iPod touch, you must first connect to a wireless network.
Touch the "Settings" icon on the home screen of the iPod touch. The iPod does not require you to press down very hard to select an icon. Using your finger, lightly tap the application you want to activate it. Choose the Wi-Fi setting and turn it on. You may need to wait a moment while the device locates available networks. Select the wireless network you want to connect to. You may have more than one option based on your location. If you are prompted for a password, enter it and touch "Join." Opt to have your iPod alert you when there is a new network you can join. This can be useful if you are no longer in range of a network you have previously used. To receive these messages, turn on the "Ask to Join Networks" feature. Tell the iPod touch to "forget" a wireless network that you no longer want to use, so it will not automatically try to connect you. Under the Wi-Fi settings, tap the ">" button next to the network you want to delete and then touch "Forget this network." Expect that some wireless networks detected by your iPod touch will ask you to sign up for a fee-based service. If this is acceptable to you, open up the Safari application from the home screen. You will be taken to a website that explains the terms of service and accepts credit card payments for wireless Internet access.
When the iPod touch was introduced in 2007, it quickly became one of the best-selling portable music players on the market. What separated the iPod touch from its competitors was its ability to access the Internet through Wi-Fi networks. If you're ready to surf the web and send e-mail with your new iPod touch, it's easy to get connected. Just a few taps, and you'll be on your way.
Tap the "Settings" icon on your iPod touch's home screen. Tap the arrow on the far right of the "Wi-Fi" bar on the "Settings" screen. Move the slider on the "Wi-Fi" bar to the "On" position. Move the slider on the "Ask to Join Networks" bar to the "On" position if you wish to be notified before your iPod touch connects to a new network. Moving the slider to the "Off" position means you must select a Wi-Fi network manually before your iPod touch will connect. Press the "Home" button to return to your iPod touch's home screen. You will see the Wi-Fi icon appear in the top left corner of your screen with up to four bars illuminated to indicate that Wi-Fi is available and to show its signal strength. iPod touch Support
http://www.apple.com/support/ipodtouch/ and ios support http://www.apple.com/support/ios/apps/
tip
How to Connect my Apple iPod Touch 8 GB to Internet
<p>Apple iPod touch is a touch screen version of its popular iPod device, similar in appearance and function of the iPhone. Like the iPhone, iPod touch is able to access the Internet, although by different means. While the iPhone usually connect to the Internet via a wireless network operator's mobile data, the only way to connect to the Internet in an 8 GB iPod Touch is the device to use built-in wireless adapter. <br /> <p><br /> <p>1. Get references to a wireless network nearby, if you are not home or do not have access to a public network without a password. If you're in a cafe, for example, ask the cashier to use the network password and you should use to connect. <br /> <p><br /> <p>2. Tap your iPod Touch "Settings" icon and "Wi-Fi." If a blue button "off" appears next to the Wi-Fi, tap it on the wireless adapter to connect the device. <br /> <p><br /> <p>3. Scroll through the list of wireless networks will appear, and then tap corresponding to your network. Enter a password - if the network requires - and tap "Connect" to your connection to the Internet iPod touch 8 GB. <br />
on Aug 05, 2011 • Apple iPod touch
tip
How do I Connect my iPod Touch to a Netgear WNR2000 Router
<p>Netgear WNR2000, a wireless-N router, you can connect to the Internet without the hassle of cables. IPod touch supports Wi-Fi (wireless) connections. If you're within range of the router, you can connect to the wireless network. Once connected, enjoy a fast transfer speeds that allow you to quickly scroll pages and run the programs enabled network. <br /> <p><br /> <p>1. Connect the iPod Touch. Tap Settings on the Home screen settings of media player to start. <br /> <p><br /> <p>2. Scroll through the settings when you come to "Wi-Fi, tap to activate the feature. IPod touch detects networks in range. <br /> <p><br /> <p>3. Select the Netgear WNR2000 Wi-Fi network can include the name has been set, so it helps to know the name. If a secure network, enter the password. If you do not know the password, your iPod Touch cannot connect to the network. Once selected, your iPod automatically connect to the network. The Wi-Fi icon in the status bar at the top. <br /> <p><br /> <p>4. Select "ON" next "Ask to Join" if you want your iPod touch to ask you to connect to wireless networks within range. <br />
How can i have an internet connection with my itouch gadget thru belkin router? thank you.
  • Touch the "Settings" icon on the home screen of the iPod touch.
  • Choose the Wi-Fi setting and turn it on. You may need to wait a moment while the device locates available networks.
  • Select the wireless network you want to connect to (Belkin something). You may have more than one option based on your location. If you are prompted for a password, enter it and touch "Join."
  • Opt to have your iPod alert you when there is a new network you can join. This can be useful if you are no longer in range of a network you have previously used. To receive these messages, turn on the "Ask to Join Networks" feature.
  • Tell the iPod touch to "forget" a wireless network that you no longer want to use, so it will not automatically try to connect you. Under the Wi-Fi settings, tap the ">" button next to the network you want to delete and then touch "Forget this network."
  • Expect that some wireless networks detected by your iPod touch will ask you to sign up for a fee-based service. If this is acceptable to you, open up the Safari application from the home screen. You will be taken to a website that explains the terms of service and accepts credit card payments for wireless Internet access.
  • 0helpful
    My ipod touch is new and has no damage done to it. i have a wireless network in my house with a full connection and i have the correct password. it recognizes my network ( my networks name is flower) and i...
  • Step 2 Choose the Wi-Fi setting and turn it on. You may need to wait a moment while the device locates available networks.
  • Step 3 Select the wireless network you want to connect to. You may have more than one option based on your location. If you are prompted for a password, enter it and touch "Join."
  • Step 4 Opt to have your iPod alert you when there is a new network you can join. This can be useful if you are no longer in range of a network you have previously used. To receive these messages, turn on the "Ask to Join Networks" feature.
  • Step 5 Tell the iPod touch to "forget" a wireless network that you no longer want to use, so it will not automatically try to connect you. Under the Wi-Fi settings, tap the ">" button next to the network you want to delete and then touch "Forget this network."
  • Step 6 Expect that some wireless networks detected by your iPod touch will ask you to sign up for a fee-based service. If this is acceptable to you, open up the Safari application from the home screen. You will be taken to a website that explains the terms of service and accepts credit card payments for wireless Internet access.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • Don't despair if you do not have a wireless network connection in your home. Public libraries often have wireless Internet access and do not charge their patrons for using it. Local cafes, coffeehouses and bookstores may also provide hotspots to their customers, but you may have to pay a fee for the service.
    • Fully charge the battery of your iPod touch before you go in search of a wireless network. Using the USB cable that came with your iPod, hook your iPod up to your computer. Make sure your computer does not go into "sleep" mode or the battery may actually drain instead of charge
    dont forget to rate me......
    good luck....
    tip
    How to put the Internet to an iPod
    <p>Apple's iPod device only with Internet capabilities, the iPod Touch. Other versions of the device can only synchronize with a computer full of music and video. The iPod Touch, however, can connect to wireless Internet networks, where available. Bringing the Internet to your iPod Touch, you need Wi-Fi settings to activate the device. Once you allow them, the iPod Touch Wi-Fi settings will be available networks, you can connect to a tap of the finger to detect. <br /> <p><br /> <p>1. Click the Settings icon on the home screen of the iPod Touch. <br /> <p><br /> <p>2. Click Wi-Fi <br /> <p><br /> <p>3. Click "On". <br /> <p><br /> <p>4. Click a wireless network in the list that appears to connect. <br />
    on Aug 05, 2011 • Computers & Internet
    I cant connect my ipod touch to internet
    Try resetting your router. This can usually be done by unplugging it and leaving it unplugged for 30 seconds, then plugging it back in.
    2answers
    Can't connect my Ipod touch to my router?
    You must be sure to what router you are trying to connect. I understand you have a ZyXel and a linksys. You must have 2 wireless networks. Your wireless network must be secured, so you just have to use the correct password. I need more details. Try this http://technicalsupport.blog.friendster.com
    did you setup a wireless network ? if you didnt go to control panal and then wireless network setup icon and follow instructions (select automatically provide network key option) then follow instructions and finish. once you did that, search through wifi on youf phone it should find your WNetwork and then connect and enjoy. if you want to use internet and have an ADSL modem, make sure that the modem is connected to the internet RJ45 plug on your router. and from router to PC.
    good luck, i hope this helps
    HTC will not connect to wireless at home
    Hello Devin, give me a chance too! may be my technician help you to fix this issue. Dial our company customer care number +1 (844) 355-5111 (toll-free). We surely help you!
    Thanks
    John
    Top Apple Audio Players & Recorders Experts
    Grand Canyon Tech
    Grand Canyon Tech
    SmartAviator
    SmartAviator
    ZJ Limited
    ZJ Limited
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
