Rocky , start by replacing spark plug and remove old gas for new.
check links below for why mowers do not start.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
check your wires and make sure there on right also dist rotor should be pointing to number one plug at top dead center TDC to get ot TDC ther are many vedeos on you tube that will show you how to do it
If a starter is able to crank the engine but it won't start you usually have either an electrical or fuel problem. It's also remotely possibly that it's compression.If an engine has proper fuel, spark and compression, it will start when you crank it. So your challange is to find out which part isn't working right. Start with fuel. Spray a little starting fluid into the air intake while someone tries to start the engine. If it starts briefly when you're spraying starting fluid, you probably have a fuel delivery problem. That could be injectors, fuel pump, fuel filter, relay, fuse... who knows what until you check into it.If it doesn't start with starting fluid, check the spark. Pull a plug wire and attach it to a spare sparkplug and set the plug on a solid metal part of the engine. Have a helper crank the engine while you watch the plug. If you have a good spark, it might just be out of timing.In any case, you'll need to start isolating the problem. Find out which part isn't working then you'll know what to replace/repair.
Carburetors could be dirty/blocked. Open throttle and spray carburetor cleaner in them, wait a few minutes, then start. Also spray carburetor cleaner again when revving. Should fix it.
Also, try starting with no choke and no throttle. It could be flooding.
Clean spark plugs.
either your car won't start, or if it does it will backfire and sputter. Then check your timing when the timing mark gets dead center on the flywheel, your number one piston should be at the top of its stroke, you can pull the plugs and check this with a pencil inserted in the spark plug hole!
you said you repl dist cap that means you don't have a crank sensor you have electronic ing module. remove your elec ing module have it tested most auto parts stores could test your module, or check your coil at the neg terminal. should have power. if not you lost your primary volt from your batt.your secondary power is coming from your electronic ing module from the module to the pos terminal on the coil, when the eng cranks,from the coil to the dist cap , from the dist cap center to the rotor then out to the plugs,this all happen pervided the timing belt or timing chain is ok. the cumbustion chainber needs 3 things , thats fuel, air, and spark.
