Akai LCT2715 27 in. LCD Television Logo
Posted on Dec 21, 2009
I fixed the power supply but don't have a
I have 2 akai lct 2715 lcds that bad electricty caused some capacitors to go. I fixed the power supplys got bone working but don't have a picture on the 2nd one .do you think possibly need to
replace more capacitors. .some have brown stuff around the bottom of them,the ones i changed had the tops buldged up with black stuff oosing out. whats the differences between capacitors with 105c and 85c .thanks for the Help
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 10, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
305
Points
Akai LCT2715 keeps shutting off or making a loud screaming noise that can only be turned off by shutting it down at the the tv
  • crashdogy May 04, 2011
    Just want to say thanks had my AKAI TV siting around for about 2 years. Its working now replaced all capacitors at the top of the power supply and 2 that went on PCB board. Yahoooooo thanks agene every one ??
I have a lct 2715 not too long ago the screen went black and the power light blinks yellow
The failure with your LCD might be due to defective capacitors in the power supply. These parts become defective due to excessive heat and fail prematurely If you are able to DIY, you can check the picture to see how defective capacitors look like.901ae86.jpg
1helpful
Akai LCT 328STA,Comes on Akai screen appears then goes off.
Akai LCT 3285TA (notice the "FIVE") uses the MLT169A Power supply. This is available from shopjimmy.com for about $100.
Accessing user mode on my AKAI LCT 2715
On my Akai LCT2715---- Ok, I had the same problem with locating USER MODE (even called Akai service HELP and that person didn't know anything)!!! even tho we looked through manual just got TV back from putting $184 in Capacitors repair (PUT IN NEW NICHICON CAPACITORS) from the standby button not woking just flashing from the Power Supply gone bad plus 2 main capacitors other than power supply that were bad. Works great now. For the USER MODE look on the remote in the bottom black area repeatedly push the P.MODE. You should have full function to adjust all in menu list WE DID.
Akai lct 2070 tv switch does not turn on tv-no sound-no tv
Most failures on this TV are due to defective power supplies. If the TV does not turn ON, you should replace the power supply.
Check this website to buy the power supply adapter and hopefully that should fix the TV.
Akai 2715 power supply
You can write to [email protected] for more info on the repair cost.
2answers
Akai TV power supply problem.
Completely understandable concern. I have fixed 9 AKAI LCT2715 power supplies for other people who have contacted me through fixya.com and 2 through my instructable on instructables.com.
I did notice that you posted this under AKAI LCT3201 TD 32in. LCD Television TV/DVD Combo troubleshooting... I do not remember posting to anything other than the problems concerning AKAI LCT 2715 27in TV's. But in any case this could be the same issue for you as I have noticed a common failure point on AKAI TV's is due to the poor power supply components they use.
As far as trust is concerned I can not really say anything more other than I do keep in contact via email about the parts that are shipped to me to let the customer know when it arrives as well as discussing payment options up front so you know what to expect. I also offer paypal as a payment option and I send an invoice via paypal when the power supply is ready to ship.
Thank you for your question and I hope this helps you understand how this general process works for more cases.
Lcd akai 2715 blinking red light
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to [email protected]
Akai tv wont come back on
Nothing......bad capacitors in power supply need replacing.....T.
1helpful
Akai LCT 2701 TD - Red Blinking lIngt
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
2answers
Akai LCT 2662 will not turn on
I'm surprise to see the repair shop telling you there nothing they can do.
The power supply can be fix if you take the time to troubleshoot it. However this is not a DIY project.
The failure is in the capacitors that are bulging out of the top or bottom. Quite visibly defective.
4- 3300uf @35V
8- 2200uf @25V
7- 1000uf @10V
1- 1000uf @6.3V
3- 100uf @25V
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
