The spay tower in the bottom fell out. should I use the dishwater
If the spray tower is not in place then water will not get to the spray arm for the upper rack. You should be able to re-install the tower. Look for small tabs at the bottom that fit into slots in the mounting. The tabs should snap in or lock when the tower is turned slightly. If the tabs are broken off you should replace the tower. You can use the dishwasher without it but he dishes on the top rack will not get cleaned and the pressure tot he bottom spray arm may be reduced causing dishes to not get completely coean.
