Microwave Ovens Logo
Posted on Dec 21, 2009
I own a Maytag Microwave that just stopped working. There is power to the outlet. Not even the clock is not working. The microwave is also the vent for the stove, which does not work. Any help would be appreciated. [email protected]
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Dec 21, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
7549
Points
21
This happened to me the microwave is at it ends life
Microwave stops randomly on its own, dispaly flickers and I get prompted to enter clock settings, what should I do to fix it
When a microwave asks for the clock settings, it has lost power. Check the plug and the outlet for damage or if it is loose. When on, vibrations can cause the plug to reposition if loose enough. Even a very short loss of power will reset the microwave. If the plug/outlet is ok, then check to make sure that the fuse for the outlet is tightened fully (breaker switches do not have this problem). Last, try another outlet as the wiring to the outlet may be loose.
Hi. I accidentally ran my Maytag MMV4205AAW on high power for about 15 minutes with nothing in it. After I stopped it, it wouldn't come back on. No surface light - nothing. My circuit breakers are...
i personally do not recommend to a consumer to work on microwaves. they retain alot of voltage!
but will refer you here....
http://www.appliancepartspros.com/repair-help/maytag-microwave-mmv4205aaw-repair/mmv4205aaw-wont-start.html
Heating element does not work
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101;,;;,;
The microwave had been working fine we now have no power at all
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Why did my maytag microwave oven power go out completely?
1 your inline fuse blew
2your magnetron t-stat poped
3 bad voltage from outlet
test the outlet with a lamp, if that works it can only be the other two
open the door, take the screww off the control panel
and the vent cover, two screws on top
behind the control and vent you will see the mag t-stat, it should read continuity, and the inline fuse should be right above it a small glass tube fuse like a car
My microwave just quit workin. It has absolutely no power.
Make sure breaker isnt tripped. If breaker isnt tripped just for the sake of knowing plug a fan or something you know that works in the outlet. If it works, you have probably blown fuses in the microwave you'll have to take microwave apart to get to them.
After plugging in too many appliances to one breaker - I had an outage. NOW - my mmv4205 won't work at all.
Hello. check to be sure that you have power to the outlet where your microwave is plugged in. If you do then plug your microwave in and attempt to set the clock. IF you can not set the clock you most likely have a blown internal fuse. Call around to the various repair shops and tell them what you need. get an estimate from at least three shops.
Maytag microwave just died.
Take it back to the store and make them do something about them. If they dont then file a complaint with the BBB no reason for you to have to deal with this when it is there problem. It sounds like there is a venting issue and more going on
2helpful
Not Working
Its most likley your control board located behind the touch pad. It may also be a temp. fuse mounted on the cabinet inside the control panel. You can ohm out the fuse to see if its good , if so replace the board.
Phil
3helpful
2answers
Microwave stopped working
Generally, you get something unless the fuse inside is blown. There is generally a fuse inside the unit when you remove the button package. First, make sure that the outlet you have is good. Plug something else into it and see that it works.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
