Cyclops torch LED flashing when plugging in to charge
Cyclops torch red LED flashing when plugging in to charge from mains power. Light does not charge and it is not working at all. Fuse looks ok as does bulb.
I remember that light, its a halogen bulbed searchlight with a sealed lead acid battery. Both technologies are obsolete, your battery is likely aged and can be replaced I think its a 17ah and about , $40. For a little more money they make a lifepo4 in the same format. If it were me though Id send it to the dumpster, led powered by lithium now equal its output but fit in your pocket.
This could indicate a bad battery. Try removing the battery and powering on the laptop. If the power LED remains white then you have a problem with the charging circuit. That means your battery could be defective or the battery charging circuit on your motherboard is faulty.
This is the spec for the 18 million thor cyclops which i presume will be the same for the 15 million. Red light on torch flashes while charging. As soon as full charge is done red light stays lit.
"Attach the barrel tip of the AC Charging Adapter to the AC Charging port of the POWER TO GO® and plug the standard two-prong plug into an appropriate, functioning 120 volt AC outlet. The red Battery Status LED indicator will flash, indicating a proper connection has been made and the unit is charging. The green Battery Status LED indicators will gradually light as the charge level rises. The POWER TO GO® must be charged for approximately 11-17 hours prior to first use. All Battery Status LED indicators will be lit solid (the red indicator will stop flashing) when the unit is fully charged.
If the red light flashes at plug in you likely have a main board that is bad. If you have to press the power button before the red light flashes you likely have a bad bad supply board. This will need to be diagnosed by a technician to be sure of the problem.
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
Cyclops C15 MIL SPOTLIGHT
