Hi Chrisn569
My suggestion to you right now is to uninstall the software, re-install it, and give the error that you received during installation.
prior to installing, i suggest you close anything running in the background.
Hello, Chris.
Here are the requirements for Roxio Creator 2010 Pro:
Microsoft® Windows Vista™ (32- or 64-bit), SP1 is required, Windows® XP SP3 (32-
or 64-bit), Windows® 7 Home Premium, Professional or Ultimate (32-or 64-bit)
Since you have Windows XP - SP3 installed, your system should support the software.
So, I would suggest that from Add/Remove Programs in Control Panel, remove Roxio Creator 2010 Pro, restart your PC and then reinstall.
If still a problem, please let us know what was the error when setting up the installation.
Hope this helps.
Well first of all tell us what operating system you are using? and did you try to install it after uninstalling it?
Thanks
My Dell model uses XP service pack 3 and while first-time installing new software, this message came up!
Sorry Guru got to go! Please send e-mail with solution ASAP Thanks! [email protected]
To NinaE
Your suggestion was already tried and when I tried to " Repair / Remove " this was when I already got these messages!!
Now the Roxio Program is still on the Add/Remove panel with 1KB and nothing on the Program List!
No amount of attempts to get round this has succeeded. Even restoring comp. to an earlier date gives any success!
So far, no joy?? Any other suggestions??
Merry Christmas anyway! I'll also keep trying!
Chrisn569
