Hi I have always had white cotton sheets and I have been adding a drop of bleach as a pre soaker to my washing and it has discoloured my white bedlinen . How can I solve this and also how do I do a big soak in a front loader as each time I stop the program the water empties out? Meredith
It's not nessesary to use bleach in frontloaders, because you have much higher temperatures than a American toploader. I think you should try to wash them on 95*, with normal washingpowder and see if ithat helps. Asko machines have prevash option, and some of the models also have presoak.
When u use front loaders you normally don't need a soak. And i don't think you need bleach. Use front loading powders for the machine. The automatic machine is supposed to work for you. The water empties out, so you can open the door.
Rate me pl if helped..............
Open the front door and load the clothing into the washing machine. Check the owner's manual for the maximum load size. Overloading the washing machine may interfere with its ability to spin the clothes and rinse them clean.
