5d
possible causes* If too much detergent was used-Run the unit thrugh a RING/SPIN cycle.-Run a NORMAL cycle with out adding detergent.PROCEDURE * This should clear the unit of excess detergent.1.- Check the draing hose and male sre it is not plugged or ****.2 Unplug washer or disconnect power.3.-Check wires harness connections to the drain pump, pressure switch, and center Cotrol Unit (CCU).4.- Check/clean drain pump filter of foreign objects.5-Plug in washer or reconect power.6.- Check draing pump.7.- Check the pressure switch.8.- Verify CCU operation bu running a Diagnostic Test or any cycle.
Hi friend,,, welcome to fixya
CHECK THESE THINGS..OK
1.Inspect the drain hose for kinks
2.Test the timer control
3.Test the lid switch (some models)
4.Inspect the water pump
5.Inspect the drive belt (belt drive only)
6.Inspect the motor coupler
The machine mite not be draing if so cheak the drain pipe to see if it is bloked or not installed properly. if the water drains out and you hear the moter running the belt might of gone. but if the machine if not making a nosie the moter might be gone and there is two things to cheak before getting a new moter 1 cheak the cables a blugged in sucurly 2 make sure the carbon brushes are ok if it seams all ok the moter might be broken or the control panel.hope this helps
5d means the follow;
possible causes
PROCEDURE
* This should clear the unit of execess detergent.
"Was this helpful?"
5d
possible causes
PROCEDURE
F33
MUST be fix by a technition Service ONLY am sorry about this inconvenient.
"Was this helpful?"
If cleaning the drain hose is not clearing the problem for you, then you need to check the drain pump and/or the drain hose from the wash tub to the pump. These areas are notorious for clogging with debris.
