For 3com type of routers, you must connect firstly to 3com setup, By:
First: open your browser and type 192.168.1.1
Second: you will find adapter setting and reset it, it all depends upon your router's software.
Third: the easiest way is to reset it from the small button in the back of your router.
You have to configure the WDS on the 3comm, configuring it to the MAC ADRESS of the BT router (if it is wireless), if not connect it by ethernet and set the 3comm as WDS allowing the other 3 more u want to add as acepted MAC ADRESS for access points.
quite often, if the router works in other houses, contact the telephone LINE company to see if there is a problem there. Alhough tiscali aren't always very helpful, ask them to do a line test and see if there is a problem with the signal to noise ratio on the line
check the NOKIA site for compatibility issues for VISTA. VISTA has compatibility issues with many softwares (which may include the improper driver for your N 72)
