Heating & Cooling Logo
Anonymous Posted on Dec 21, 2009
Gas furnace, main burner ignites the other 2 don't. then shutdn.
Rheem/Ruud Silhouette II gas furnace UGPH07EAUER. HSI (ignitor) lights up at main burner head. Gas flows and is ignited at main burner 1st head. There are three burner heads. The flame sensor is located at the third burner head. the gas is not ignited at the 2nd and 3rd heads and because the flame sensor rod does not detect heat the furnace shuts off the gas and cuts the fan off 90 seconds later. Cleaned the flame sensor. Once the main burner flames up I can manually light the 2nd and 3rd burners and the unit will run until the thermostat shuts it down automatically. Help
Anonymous
Level 3:
President:
  • Master 1,015 Answers
  • Posted on Dec 21, 2009
Anonymous
Master
Level 3:
President:
Answers
1015
Questions
0
Helped
451797
Points
3407
Between the burners is a small rail in the pressed steel where the flame runs across to light the other burners and it sounds like there is dirt or debris in the step over rails causing the problem. You will need to use some compressed air on those rails to clear them out. Once the rails are clear the other two burners should ignite right away.
Testimonial: "I did not expect such a quick response. These are hard times for us and we really appreciate your help. Thankyou for sharing your expertise."
  • Anonymous Dec 21, 2009
    Also you can try using a small flatblade screwdriver to clean out and spread open the rail slightly to help the gas flame travel to the other burners.
Richard Kozlowski
Level 1:
  • Contributor 0 Answers
  • Posted on Feb 09, 2014
Richard Kozlowski
Contributor
Level 1:
Answers
0
Questions
0
Helped
930
Points
0
My problem as well thanks for the solution!
My CUHN 75A-1 gas heater will not light. 4 flash code = high limit or rollout switch open. when I cycle start, the large fan runs, where normally it only starts after the heater lights.
  • What Is Electronic Ignition?
    Jupiterimages/Getty images The electronic ignition system in a gas furnace is a modern development that provides more reliable performance than a standing pilot and offers energy savings through better furnace efficiency. There are two basic types of electronic ignition systems:
    • An intermittent pilot system uses an electronically controlled high-voltage electric spark to ignite a pilot light and subsequently the main burners when the thermostat calls for heat.
    • A hot surface ignition system uses an electronically controlled resistance heating element, not unlike a light bulb filament, to ignite the gas burner.
    Understanding some of the basic components of a modern furnace will help you identify the type of furnace you have and narrow down the list of potential problems.
  • 02of 05
    Types of Electronic Ignition Furnaces
    Design Pics/Getty images Most furnaces with electronic ignition are either conventional induced draft furnaces or high-efficiency condensing furnaces.
    Induced draft furnaces use a small fan to draw the combustion gasses from the combustion chamber and out of the house through the flue (chimney). This system is more reliable and safer than old conventional furnaces, which relied on a natural draft coming in from an opening at the front of the furnace. Induced draft furnaces use either an intermittent pilot (IP) or hot surface ignition (HSI) instead of a standing pilot light. The combination of electronic ignition, electronic controls, and artificially created draft improves the efficiency of induced draft furnaces over older conventional models.
    Condensing furnaces use two heat exchangers, where conventional furnaces use only one. After the gas is burned to heat the primary heat exchanger, the secondary heat exchanger draws heat out of the hot exhaust gasses, cooling them to the point that the water vapor in the exhaust condenses into water. The resulting flue gases are so cool they can be vented outside via a plastic (PVC) pipe, while the condensed water is run to a floor drain. Condensing furnaces use hot surface ignition (HSI).
  • 03of 05
    Troubleshooting an Intermittent Pilot (IP)
    Michael Interisano / Design Pics / Getty images Typically found in induced draft furnaces, an intermittent pilot ignites the burner gas with a high-voltage spark only when the thermostat calls for heat. Once the pilot is lit, and the main burner senses the pilot flame (using a flame sensing rod), the main burner ignites. The intermittent pilot flame goes out after the heating cycle and remains off until the next time the thermostat calls for heat.
    The furnace gas valve for this type of furnace is identifiable with its solenoid designations: MV, PV, and PV/MV - where MV = main valve, PV = pilot valve, and PV/MV = common.
    Common problems with IP ignition include:
    • Ignition doesn't occur, and the furnace won't go on
    • A spark is present, but the pilot won't light
    • Pilot lights, but the main burner doesn't come on
    • Burners ignite but turn off after a few seconds
  • 04of 05
    Troubleshooting a Hot Surface Igniter (HSI)
    The hot surface igniter (HSI) is the most commonly used electronic ignition system. It works like a light bulb filament, heating up when electricity is passed through it. Most are made from silicon nitride or silicon carbide. The igniter is located in the flow of gas entering the burners.
    When the thermostat calls for heat, 24 volts are sent to the electronic ignition control module, which energizes the furnace blower and other systems and sends 120 volts to the HSI. The HSI heats up to around 1,800°F to 2,500°F and glows red-hot. Then the gas valve opens, and the burner gas is ignited by the HSI. Once a proper flame is sensed by the flame sensor, the HSI turns off and stays off until the next heating cycle. In some furnaces, the HSI also serves as a flame sensor (called local sensing) instead of having a separate sensing rod in the burner flame (remote sensing).
    Under normal conditions, an HSI should last for three to five years, and they eventually crack and need to be replaced. This can happen sooner if the oils from your skin get on the element through improper handling. That means: Don't touch the element with your bare hands!
    HSIs usually cost between $25 and $50, and it's a good idea to keep a spare on hand, in case one goes out at night or on the weekend, when you can't easily get a new part.
    Here are some of the common causes of HSI failure:
    • Premature failure due to improper handling (oil from skin got onto element)
    • Improper igniter
    • End of normal usage life cycle (keep a replacement on hand)
    • Voltage in the furnace electrical circuit is too high (over 125 VAC)
    • Severely dirty air filter, causing the high-temperature limit switch to cycle the furnace ignition on and off frequently
  • 05of 05
    Reading Control Board Codes
    Mohd Firdaus Mohd Damanhuri/EyeEm/Getty images Most modern furnaces with electronic ignition systems have an integrated circuit board that controls many sophisticated processes. The boards can perform self-diagnostics and provide failure codes, similar to the diagnostic computer in your car.
    If a failure occurs, LED lights on the control board light up in a blinking pattern to indicate a specific failure code. The codes are listed in a chart in the owner's manual and usually on a door or access panel on the furnace. Control boards are usually located inside the blower compartment of the furnace. If the board has blinking lights, refer to the chart to decipher the code and help identify the problem area with the furnace.
I have a Ruud Silhouette II plus LXE that the hsi is energizing when the thermostat is in the off position. We have not used the heat in months only the A/C.
If the inducer motor is not turning on, it is not getting a call for heat and the hsi should not be energized. If it is energized without a call for heat, then the circuit board will need to be replace in the furnace...it has stuck contacts on the hsi relay.
Will not ignite
check the igniter it must need replacing
2answers
Ruud Silhouette II Fails to Ignite
sounds like you have bad flame sensor or the sensor is in a bad postition. To get eliminate the lockout turn the power off to the unit and back on again. Look at the circuit board light and see what the troubleshooting code is.
3helpful
Heater lights for about 5 sec and then goes out
One flash on a Ruud furnace indicates failure to ignite. There is a viewing port on the furnace where you can watch the flame. If the ignitor is igniting the burner and then 2 or 3 seconds later, the flame goes out; you most likely have a flame sensor that is dirty or not working. Check to make sure you are getting gas. Check the connections of all wires to the control board. If the sensor is not part of the ignitor, see if you can get to it to clean it with a small wire brush. Make sure there is a good ground connection between the board and furnace frame. If the flame is not traveling all the way to the flame sensor, clean your burners. If the flame burns inside the burners, you may have weak gas pressure. Good Luck.
Top Heating & Cooling Experts
Paul Carew
john h
