1994 Honda Accord Logo
Posted on Dec 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there a rear seat release on a 94 accord - 1994 Honda Accord
Anonymous
Level 3:
  • Master 448 Answers
  • Posted on Dec 21, 2009
Anonymous
Master
Level 3:
Answers
448
Questions
Helped
332405
Points
1572
I believe this procedure applies to your 94 Accord:
With your hands, press down on the seat cushion where it meets the seat back. Locate the retaining bolt(s). Some models retain the seat with one bolt in the center; others use two, evenly spaced left and right.
Remove the retaining bolt(s).
Lift the back (toward the rear of the car) of the seat bottom upwards while rotating it toward the front of the car.
Disconnect the hooks at the front edge (during the rolling motion) of the seat and remove the seat bottom.
Remove the carpet (in the luggage compartment) from the rear of the seat backs.
Remove the seat back mounting bolts from the luggage compartment side.
Lift out the seat back.
If the rear side bolsters or pads are to be removed, remove the lower mounting bolt, then push upward to free the hooks.
Hope this helps you.
How to remove broken side rear glass 95 honda accord
94-97 Honda Accord Rear Side Window Install - YouTube
? 6:00
https://www.youtube.com/watch?v=Cgn0EmuY9NU
Jan 8, 2013 - Uploaded by Function Factory
94-97 Honda Accord Rear Side Window Install ... How to fixreplace install a broken power window regulator ..
How do I life the rear seat to fold down the back of the seat?
will need to try and see if latch is damaged or debris is jammed in latch with the other side up look under at latch also check the cable --you can try kneeling on seat and bounce and pull on tab to try and get it to release
How to remove rear seat in 2008 accord ( the seat you sit on)
Most back seats have two hooks on either side of the seat. Pushing in quite hard on the front of the seat and lifting it up is the usual way to release them. Hope this helps.
Where is the fuel pump on a 94 honda accord?
under the rear seat if you lift it there should be a ring of 10mm bolts remove these and the pipe and electrical connection and out it comes
2answers
Do you have to drop gas tank to repair fuel pump on 94 accord ex
You usualy drop tank to get fule pump but on this car you may be able to get to it if you remove the rear seats. by doin this you expose the top of the fule tanks(right where the fule pump sits)
2helpful
How do you remove front seats in a 94 honda accord lx?
Unbolt the four bolts under the seat attaching the seat mount to the floor.
1helpful
How do you remove the rear seat of 2004 honda accord
Release the two latches at the front of the seat cushion (pull back on the latches to release the front of the cushion).
Remove the seat cushion bolt and remove the cushion (it’s roughly in the center. You have to insert a socket extension between the back and bottom seat cushions to take it out, after you find it by pressuring the bottom cushion and looking back in there).
Remove the bolts (each side) securing the seat side bolsters (they are easy to see once the bottom cushion is removed), then remove the side bolters (gently release the clips that hold them in).
Pull the seat forward, then remove the fasteners securing the seat hinge (seat pivot bracket) and remove the seat backs.
2answers
Where is the button to open the fuel door on the Honda Accord euro 2009?
Please Check Near the Driving Seat With boot (rear door) Open Liver.
3helpful
4answers
1helpful
FUEL PUMP
the fuel pump is under the back seat. two release pins and the rear seat lifts out
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
