SOURCE: Memory Full but no pics
hi moziz;
you may try resetting it to factory settings, try to search for it in the camera menu. as for your second question; some cameras have internal memory,thus doesn't need memory card while others don't have internal memory and needs memory card.
ill wait for your reply. :)
SOURCE: take without a memory card
No, the A420 does not have internal memory. The card that came with the camera is only intended to allow you to try the camera to make sure it works. You should really purchase a new SD card. New ones these days are literally capable of holding hundreds if not thousands of pictures, and cost less than $7. Here's an example:
http://www.amazon.com/SanDisk-Memory-Card-SDSDB-2048-Package/dp/B000J47W12/ref=sr_1_1?ie=UTF8&s=electronics&qid=1231445448&sr=1-1
SOURCE: hi, i have a TECHNIKA SH-8360 digital camera and
that depends if your camera has a bit of built in memory than you can if in doesent then you can't good luck:)
